Sponsored by: Kumho
mjb1962 qick question for u
Old Dec 20, 2003 | 06:44 PM
loui6035's Avatar
loui6035
hey im the one that asked u about the steering stops for the 89 f150 i was just wondering how u go about adding shims or watever you do to add to it.
Old Dec 20, 2003 | 06:56 PM
MustangGT221's Avatar
MustangGT221
Don't you just have to clean out the hole (maybe re-tap it to make sure the threads are good) and put a bolt in it.
Old Dec 21, 2003 | 06:26 PM
mjb1962's Avatar
mjb1962
The steering stops appear to be bolts threaded into the steering knuckles. They are located at lower rear inside face of the knuckle. They have a 9/16" hex head.
I just looked at mine, I used 3/8" ID washers built up about 1/4" thick and still had decent thread engagement. This eliminated the tires from rubbing on the radius arms.
Mark
Old Dec 21, 2003 | 09:26 PM
loui6035's Avatar
loui6035
hey me again
one more question did u hafto take the wheel assembly off or can u just do it while the truck is all togeather and on the ground
Old Dec 22, 2003 | 04:28 AM
mjb1962's Avatar
mjb1962
You can get to them from under the truck with the wheels on. Use a ratchet with a 9/16" socket, I'm pretty sure it's 9/16".
Mark
Old Dec 22, 2003 | 01:37 PM
loui6035's Avatar
loui6035
thanks alt man wat size tires do u hsve on ur 150
Old Dec 22, 2003 | 06:10 PM
mjb1962's Avatar
mjb1962
35x12.5R15's on 15x10" rims with 3.75" backspacing.
Mark
Salsa91
15
Jun 10, 2015 11:10 PM
Greywolf
Apr 9, 2012 05:39 PM
tgowers
Feb 5, 2009 11:47 AM
AGORA
2004 - 2008 F150
Dec 13, 2004 04:54 PM
guitars2
Nov 5, 2001 09:29 PM
