FE Head ?
Old Nov 11, 2003 | 08:44 PM
79blueoval's Avatar
79blueoval
FE Head ?
Could someone please identify these heads---C8AEH
Thanks.
Mike.
Old Nov 12, 2003 | 02:10 AM
Ratsmoker's Avatar
Ratsmoker
The C8AE-H is a very common casting. They are popular for porting and can flow every bit as good as a 428CJ head with a little work. They were found on all FEs from 68 - 71 or so.
Old Nov 12, 2003 | 08:36 AM
79blueoval's Avatar
79blueoval
I know enough about FEs to be dangerous could you give me some areas to look at to see why the were discarded,they are still together and there is nothing obvious --broken springs,cracks or burnt valves in fact the look fairly fresh--clean paint and not a lot of carbon in the chambers.I am going to pull them apart to check the guides but how do I tell if the seats a recessed to far as to be usable and if they are would these castings be worth putting new seats in them.These heads are for a 75 F-350 2x dumptruck. Thanks for your response.
Old Nov 12, 2003 | 08:50 AM
Ratsmoker's Avatar
Ratsmoker
You may find the valve guides to be extremely worn. A good machinist will be able to give you the precise condition. Even good pictures won't help anybody find small cracks or detect warpage. They did not come with hardened seats from the factory so you may have to have them installed. They are a good head but figure out what it takes to get them rebuilt properly. It may not be worth it depending in their condition. It was going to cost me about $900 to get mine rebuilt right. I went for the edelbrocks.
Old Dec 22, 2003 | 04:34 AM
bob arrington's Avatar
bob arrington
what year did they start puting hardened seat in the heads ? was it just certain ones or was it all of them? Thanks Bob
Old Dec 22, 2003 | 07:10 AM
fordman428's Avatar
fordman428
in 73 i believe they went to hardened seets in all of them due to emissions and it cost me $288 to get my 390 heads redone, new seets, guides, magna fluxed, hot tanked, milled .10 new valves were about $75 so its not cheap to rebuild old heads.
Old Dec 22, 2003 | 09:22 AM
JonnyB69's Avatar
JonnyB69
Just to throw my info in the ring here, I have those same heads on my engine, and with just some basic porting, new exhaust valves,valve guides, and hardened seats, it was roundabout $500 to get em done. They work great, and I only wish i had the time and money to get more exhaust flow out of them with headers.
Old Dec 22, 2003 | 11:02 AM
bob arrington
many thanks
Old Dec 22, 2003 | 07:39 PM
Andysutt's Avatar
Andysutt
I have a set of those.
Im using them now at the moment...
But I had good valves and such in them
I cleaned them up, ported them, springs were still good, etc
My motor had been rebuild 5 years before I got it
But it sat those 5 years, just started occasionally
So I got mine pretty cheap
Old Dec 22, 2003 | 09:29 PM
baddad457's Avatar
baddad457
How do you know there's not enough flow from the exhaust ports with headers? Who said how much was enough?
Old Dec 22, 2003 | 10:48 PM
Putt's Avatar
Putt
I think he means, he needs headers to utilize the extra flow from the port work. I think even without port work, you need headers.
Also, the hard seats were installed due to falling lead content of gas in the mid '70's, it doesn't affect the emissions that I'm aware of. Could be mistaken.
Putt
Old Dec 22, 2003 | 11:17 PM
baddad457's Avatar
baddad457
Putt
Now that makes more sense Yes headers are a must with any FE. Unless your's was blessed with the factory cast iron banana pipes
Old Dec 23, 2003 | 08:40 AM
JonnyB69's Avatar
JonnyB69
Yep, y'all got it. I just need headers to use the flow the heads are capapble of. Sorry, I guess I worded that like a kindergartener.
