Sending unit for Temp Gauge?
Does anyone know where it is. I'm new to this forum. I just inherited my Grandpa's 79 F-150 It has a 351M in it. I'm gonna start going through it. I just dropped the fuel tank on it cause it had been setting for over a year. I got it running pretty good but the temp gauge is not working. Anyone know or got any idea i'd appreciate it.
Nate
Nate
Generally on ford motors, the temp sending unit is in the intake manifold, usually center and towards the front near the water outlet and the thermostst housingon the left of the intake.then their is a wire that simply pushes on to the top of the sensor and runs to the insturment panel, so your problem could be in a bad temp sensor wich i would recomend replacing because it's cheap insurance, or your problem could be a bad gauge or corroded wire, i recomend just swapping out your temp sensor before digging into wires and tearing up your dash.
MufassaMaxx
04-16-2002 10:05 AM
