Safe pyro temp?
Old Mar 22, 2003 | 02:16 AM
Nate9982's Avatar
Nate9982
Safe pyro temp?
Ken
I have a 99 psd and just got done installing a Diablo Delta Chip, 4" exhaust and AFE intake, and pyro. Last night I was pulling a hill in 6th gear and saw 980 degrees F. I took my foot out of it in feer that my engine was going to melt. My pyro is mounted on the down pipe so I know their is going to be some temperature inacuracy. What is a safe temp with the location of my pyro?
Second question is, I know most chip makers recomend that you let off the gas before switching between performance programs. Is this required for the Delta Chip?
Thanks
Props to this web site I couldn't live without it.
Nate
Old Mar 22, 2003 | 05:43 AM
Quadzilla's Avatar
Quadzilla
Safe pyro temp?
I've heard a rough estimate that a pyro with the probe downstream from the turbo will give a reading that is approximately 300* lower than one mounted upstream, so if that's true, 980* was a good time to back out. You ought to remount the probe pre-turbo, and take out the guesswork.
I've never heard that you're supposed to back out of the throttle before switching programs. There isn't that much of a difference between the different power levels for that to be necessary.
That is, of course, only my opinion. I'd be anxious to hear what the webmaster has to say on the subject.
Old Mar 22, 2003 | 09:04 AM
FTE Ken's Avatar
FTE Ken
Safe pyro temp?
Yes, its recommended that you back off on the throttle momentarily while switching, especially if the engine is close to changing gears.
Old Mar 22, 2003 | 01:51 PM
Quadzilla's Avatar
Quadzilla
Safe pyro temp?
I didn't know that. I typically don't change very frequently, but will keep it in mind in the future.
Thanks, Ken!!
Old Mar 23, 2003 | 04:48 PM
PSD_Power's Avatar
PSD_Power
Safe pyro temp?
I was wondering the same thing. My engine light comes on when mine hits about 900 deg. Not quite sure why??? Mines mounted on the down pipe also
05 f250 6 inch lift
Oct 26, 2010 07:51 AM
chrisbraziel
Sep 24, 2010 11:39 AM
YoungFordAddict66
40
Dec 15, 2009 11:23 PM
redmt77
Jan 6, 2007 11:41 AM
why165
Feb 3, 2006 12:01 PM
