1978 - 1996 Big Bronco
Shifting problems?
Old Dec 16, 2003 | 12:57 PM
Whitty's Avatar
Whitty
Shifting problems?
I have a 1985 Bronco with a 302. I just put the motor in changing from a 300. The clutch worked fine untol I changed the motor. I had a guy adjust the clutch and it worked fine for about 2 miles and I turned the motor off. Got back in the bronco and it would not go into any gear. I think we found fluid leaking from the master or slave cylinder. Do you think it is the clutch or the cylinder(s). ANy info would be great...
Old Dec 16, 2003 | 08:16 PM
Stokes's Avatar
Stokes
well if you found the leak on the slave cylinder, its my guess to start trying to stop the leak there. sorry thats all i got on what you have posted.
ige1963
Jan 25, 2015 10:23 AM
Snowturtle
Aug 19, 2014 09:16 AM
RDavis
Dec 21, 2007 04:52 PM
vmaxvboost
Bronco II
Jan 7, 2007 01:00 PM
woodioh
Mar 27, 2001 04:12 PM
