Changing clutch '63
Old Jan 24, 2015 | 07:12 PM
ige1963's Avatar
ige1963
Changing clutch '63
Many of the clutch change threads discuss the common problem of the clutch push rod being too short with the new clutch. I just changed my clutch and while researching it I kept running into that same problem on here and other related Forums. Well, I know the rod didn't shrink so what gives? I have a theory and I think it worked so I wanted to share. After 51 years, I think the drivetrain sags because the motor mounts deteriorate making the rod have to reach further for the fork.
I thought of this when I had to jack up my motor so that the old clutch would slide out the bottom of the bell housing (btw clutch was newish but throw out bearing was fried - never fully disengaged apparently). So I changed the motor mounts. New clutch and pressure plate slid right in, and the rod was fine! I had to adjust it back quite a bit in fact. Also, when I put the drive shaft back I could tell by the wear that it was reaching for the tranny by about another 3/4 inches!
Sorry so long. Any experience with this anyone? (Oh, it clutches and shifts fine now)
Old Jan 25, 2015 | 10:23 AM
sseebart's Avatar
sseebart
Glad it worked for you. When I did the clutch on my 62, the pushrod was also too short, even with new motor mounts. I assumed that the geometry of the clutch assembly was slightly off from the factory original. In any case, I fabricated a replacement.
~Steve
sandman42
16
Feb 17, 2013 01:36 PM
robertspangler
Jul 28, 2010 11:26 AM
wickedinhere
13
Dec 10, 2008 07:58 AM
865.0F150
Dec 14, 2007 10:38 PM
fordflaresides
Aug 1, 2004 02:34 AM
