Compression ratio for 460
Old Dec 15, 2003 | 07:36 PM
F250SC's Avatar
F250SC
Question Compression ratio for 460
Anyone care to tell me what my compression reading should be on my F250 with a 460? How much difference is acceptable between the cylinders?
Old Dec 15, 2003 | 08:25 PM
catmandu79's Avatar
catmandu79
That would depend on what year it is, but we will assume that it is a`74, so it would be approx. 8.5 to 1. `68 to `72 approx. 10.5 to 1. 8.5 to `73 and on.
Old Dec 15, 2003 | 09:54 PM
F250SC's Avatar
F250SC
Great reply, but I believe I asked the wrong question. I am trying to see what type of compression reading I should get while doing a compression test. Not sure how to state what I am trying to do I guess.
Old Dec 16, 2003 | 05:22 AM
DeenHylton's Avatar
DeenHylton
It's not so much what the compression reading should be but how much differance between cylinders. If all your readings are with 10% your probably O.K.
It's when you have 6 or 7 cylinders reading 140-145 lbs. and then find 1 or 2 reading 80-100 lbs. that's when you know you have a problem.
Deen
Old Dec 16, 2003 | 09:38 AM
F250SC's Avatar
F250SC
Thanks Deen! I will start there.
sisabdulax
Mar 17, 2015 03:06 PM
1993460F250
18
May 17, 2013 11:28 PM
blazinjames
Jun 28, 2012 06:22 PM
BMcT
Feb 22, 2011 12:13 PM
mikefender
Apr 11, 2009 06:12 PM
