highboy 460 swap
Old Apr 11, 2009 | 01:27 PM
mikefender's Avatar
mikefender
highboy 460 swap
I'm planning on swapping a 460 from a 74 tbird into my 1977 f250 4x4. I found a 460 in a 73-79 ford van. Will the brackets and pulleys work? It has power steering,a/c, and alt, and thats what I want. Would it have a rear sump oil pan? Would the exhaust manifolds work better than the birds? Also the a/c compresser isn't square like mine its 8 sided and smaller, would it work with factory air?
Mike
Old Apr 11, 2009 | 03:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mikefender
I'm planning on swapping a 460 from a 74 tbird into my 1977 f250 4x4. I found a 460 in a 73-79 ford van. Will the brackets and pulleys work? It has power steering,a/c, and alt, and thats what I want. Would it have a rear sump oil pan? Would the exhaust manifolds work better than the birds? Also the a/c compresser isn't square like mine its 8 sided and smaller, would it work with factory air?Mike
Econoline engine mount brackets and the rubber insulators will not work in F100/350's whether it's 2WD or 4WD.
1975 was the first year for a 460 Econoline. 1969/74 Econolines are a different design, the largest engine available was the 302.
1975/77 Econolines have round headlamps, 1978/91's have rectangular headlamps.
The two 460 A/C idler pulleys are the same.
The vibration damper/flywheel might be the same, they might not be...if the Econoline is a 1979 or later.
There were two different 1979 460's. One engine used a weighted spacer, one did not. The block casting numbers will be different.
D1VE-6015-AB was used from 1971 thru 1978 and on some 1979's.
D9TE-6015-AB was used on some 1979's, and thru 1986.
The flywheel and vibration damper must match the specific casting numbers.
Waterpump pulley's, P/S pulley's, the outer pulleys on the crank might be the same, they might not be the same...it all depends on what year that 460 Econoline is.
The A/C compressor used in 1973/76 Birds (Lincoln Mark IV's, some LTD's) is a Frigid-Aire swash plate design, and is not compatible with the York compressors used in other vehicles.
The A/C may not be any good....if any of the hoses have been removed, if any parts have been removed where freon is a factor.
Once outside air gets into the compressor, condenser, dryer tank or expansion valve, the entire system has to be evacuated within several weeks...otherwise you can kiss these parts goodbye.
Old Apr 11, 2009 | 06:12 PM
mikefender's Avatar
mikefender
I was going to use the L&L mounts, all I want off the van is brackets and pulleys and maybe exhaust if it will work on the tbird 460 in the highboy
Mike
oregontrailsman
Engine Swaps
Nov 12, 2014 07:12 PM
vinf100
1978 - 1996 Big Bronco
Oct 2, 2011 09:28 AM
vee10td
Aug 15, 2011 10:34 AM
jam460
Dec 7, 2009 11:21 AM
hotrrod69
Engine Swaps
Apr 4, 2006 09:13 AM
