Sponsored by: Real Truck
Replacing SD antenna for shorter unit
Old Dec 2, 2002 | 05:42 AM
Kurts50's Avatar
Kurts50
Where can I get a shorter antenna for my new SD? When I drive into the garage, the antenna scraps and bends back on the garage door the whole way into my garage. I only have a couple inches between my cab and garage door.
How does one remove the antenna if I find a shorter one? Thanks, Kurt:-(
Old Dec 2, 2002 | 06:46 AM
Yeti's Avatar
Yeti
Ebay has some nice billet aluminum attenas, short to long, I haven't looked to see how they come off.
Old Dec 2, 2002 | 07:40 AM
jaxf250's Avatar
jaxf250
If the replacement antenna is just the whip, it should simply
screw onto the post that is under the factory antenna. At least that
is how my 2001 is set up. I remove/replace my antenna all the time
when going thru the local car wash.
If you are talking about a replacement unit that replaces the whole
mount base and wiring, then that is another story. You will prob. have
to go under the hood somehow to remove the whole unit. Let us know
what you find and how it works reception-wise compared to stock.
-- Bob
2001 F250 SD CC Lariat, V-10, 4.30, 6' Bed, 4x4, Auto, K&N FIPK-2, SCMT-tuned, BFG 295/75/16 AT's
Old Dec 2, 2002 | 11:14 AM
vinny8's Avatar
vinny8
I have a shorty antenna on my truck. It's a horse head..I get alot of compliments on it. Check out Frogworks International, Inc. on the Internet. I think it's Frogworks.com.
Very easy to install.
Lisa
Old Dec 3, 2002 | 10:55 AM
UNIMOG's Avatar
UNIMOG
You could always just clip off the length of the stock antenna that scraps, (IE: custom height to your garage). Raid the kid's toy box for a small plastic sphere to finish it off if you like, or just file it smooth and touch-up with black paint to avoid rust.
I'd leave it a little higher then the roof of your truck, as a "warning you are about to hit the roof and do lots of damage" indicator.
Mark Peterson '02 F250 CC, SB, V10, 4x4
Old Dec 3, 2002 | 05:28 PM
Waxy's Avatar
Waxy
Old Dec 4, 2002 | 08:55 PM
turbodiesel's Avatar
turbodiesel
In order for your FM reciever to work at optimum levels the antenna must be 31" TOTAL LENGTH, (ever wonder why all replacements are the same length?) this means you would be better off to bend it in such a way as to lower the overall hieght (the "zig-zag" shape seems to be popular) than to cut it, or try to find a shorter replacement. Or you can follow the HAM radio OP's example and use a coil or "loaded" mast ant. the overall hieght would be lower, but the TOTAL LENGTH of wire would remain 31".
Old Dec 4, 2002 | 09:18 PM
MNCamper's Avatar
MNCamper
Post Replacing SD antenna for shorter unit
I had the same problem with the garage when I brought my new truck home. Removing the antenna was my first 'mod'. I found a little plastic Caplug to cover the stub and keep stuff out of the threaded hole. Since I am in a large metro area, I get by most times without having the antenna on the truck.
I was at Fleet Farm today and they have a nice selection of replacement antennas. Started at about $6.00, I think.
2003 F350 Regular Cab XLT 4WD V10 6-Spd 3.73LS - Ordered 06-Sep; Received 14-Nov
Old Dec 4, 2002 | 09:40 PM
bcs's Avatar
bcs
I got a short little flexible (rubbery looking thing) ant at AutoZone for $4.99 seems to work just fine for me. It does bend in the wind. Even the lower power FM station that I often listen to, about 70 miles north, seems to come in just as well. Makes getting the truck in the garage a little easier, also it does not hit the camper
Old Dec 5, 2002 | 05:52 AM
Kurts50's Avatar
Kurts50
Thanks for the replies, I will check the stores which were mentioned for something shorter. Radio Shack might also have a good selection. Thanks!
wrvond
May 24, 2016 10:31 AM
mpally
2009 - 2014 F150
18
Dec 9, 2012 12:59 AM
MikeCT
Sep 25, 2003 11:43 AM
mzimmers
15
Aug 11, 2003 08:08 AM
dmutsch
Feb 24, 2000 11:45 PM
