Vacuum Pump Tick
Old Dec 13, 2003 | 08:07 AM
Gr8ride's Avatar
Gr8ride
Vacuum Pump Tick
Howdy,
I have a 93 F250 with a 7.3L diesel.
When I put my foot on the brake the vacuum pump ticks, it didn't use to do this. Is this a good thing?
Sometimes when I put the brake on the pedal is so hard it won't go down but maybe an inch. When it does this there is very little if any braking done. If you let off the pedal and then pump it once or twice the rock hard pedal goes away and then you can stop. Any ideas on what this might be?
Thanks,
Gr8ride
Old Dec 13, 2003 | 08:12 AM
luckild's Avatar
luckild
Vacuum pump needs to be serviced or replaced, but before that is the check valve/filter in the system ok? Check it out.
Old Dec 13, 2003 | 06:13 PM
Gr8ride's Avatar
Gr8ride
Do you know where that valve is?
Gr8rided
Old Dec 15, 2003 | 12:16 PM
Gr8ride's Avatar
Gr8ride
All fixed it was the check valve.
Gr8ride
Old Dec 15, 2003 | 03:24 PM
luckild's Avatar
luckild
GOOD DEAL!!!!!!!!!!!!!!!!!!! DRIVE ON DUDE!!!!!!!!!!!!!!!!!!!
Gr8ride
Dec 1, 2006 07:28 AM
Gr8ride
Jun 23, 2005 07:12 PM
Gr8ride
Dec 3, 2003 11:33 PM
Gr8ride
Apr 20, 2003 09:30 AM
Gr8ride
Feb 16, 2002 03:58 AM
