Sponsored by: Auxito
Right Blinker
Old Dec 24, 2003 | 01:23 PM
grayge's Avatar
grayge
Do you have a wiring harness on the back of the truck for a trailer? You might want to check that out for loose connections before spending the money on a switch. Basically that's the only spot where the wires are exposed to the elements. I had a very similar problem and that took care of it.
Old Dec 26, 2003 | 12:31 AM
kjrf100's Avatar
kjrf100
I don't know if this is your problem or not,but I just had a VERY similar problem,and it ended up being a frayed wire in the steering column. I got one of the chilton books and finally figured out how to get to the wire(it's located on left side of column where turn/wiper control attaches), You have to remove the ignition and trim around column(all clearly shown in chilton manual)(also,don't forget to disconnect battery) I fixed this problem the 1st time by just wrapping tape around frayed wire,and the problem returned. So this last time I added a section of wire to it.(seems that may be the problem here.TO SHORT OF A WIRE) Anyway,it's something for you to try,it fixxed my problem! Keith
Old Jan 7, 2004 | 11:34 AM
Doorgunner808's Avatar
Doorgunner808
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452369135 found these on ebay for whoever is interested. They are 3 ford shop manuals on dvd/rom format. From 1996 to 2004. Just thought Y'all might be interested.
DG808
SuperDuty93
Aug 30, 2013 11:54 PM
sansinga13
Mar 16, 2012 12:17 PM
STRANGER RANGER2
Oct 20, 2008 10:22 AM
rush2112
Nov 30, 2006 05:49 PM
Cyberbug
Aug 26, 2003 03:12 PM
