ignition key gets caught, doesn't turn.
Old Jun 17, 2026 | 06:44 PM
mOROTBREATH's Avatar
mOROTBREATH
A couple weeks ago when trying to start my truck for the 14th time that day, the key all of the sudden didn't want to turn right, if I fidgeted with it for a sec it might go once but not twice in a row.
Sprayed with lube and didn't help. Used a new spare key I had and it didn't help.
So do I need to replace just the inside lock tumbler or the whole switch assy?
Thank you.
Old Jun 17, 2026 | 06:49 PM
Brian1950F4's Avatar
Brian1950F4
You should just need to change the lock tumbler. The key switch works when you fiddle around and get it to turn?
Old Jun 17, 2026 | 06:57 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
It probably could be saved with a disassembly and a cleaning/replacement/renewal of the tumbler internals such as pins and springs.
Old Jun 17, 2026 | 07:12 PM
mOROTBREATH
Yes it does work when it finally allows itself to turn.
Other brian, How hard is it to disassemble?
Old Jun 17, 2026 | 07:51 PM
lshort's Avatar
lshort
I had that problem with my 55 what I did as a temporary fix was take the lock cylinder out and removed all but 1 of the brass tumblers, that was over a year ago.
It proves the saying that there is nothing more permanent than a temporary fix that works.
First I removed all of the tumblers but discovered that the key would just fall out of the ignition so I put 1 back in
Afte thinking about the fact that anyone who had the slightest clue what they were doing could start my truck in 15 seconds with a couple alligator clip jumpers
I decided I was just leaving it as is. I am just relying on the no exterior door handles, unmarked Hurst shifter T handle, starter push button and clutch pedal for security
Old Jun 17, 2026 | 08:16 PM
bmoran4's Avatar
bmoran4
I haven't disassembled a 1956 one to give any further specifics.
Old Yesterday | 05:47 PM
8pack's Avatar
8pack
Easy enough to add a hidden switch on the wire to the coil and then nobody will figure it out! I did that on one of my cars. Cheap and cheerful and near impossible for a thief to sort out without knowing what they are looking for and these days they want in and out in seconds.
Old Today | 09:16 AM
lshort's Avatar
lshort
Yes, you could have a switch that grounds down the neg side of the coil, if you have a tach that wire is already inside the cab,
any old ford is ridiculously easy to hot wire, Ford conveniently put everything you need on the starter relay and even labeled the terminals.
Take the "I" wire off the solenoid connect it to 12 V+ and touch the "S" terminal with a jumper is all you need
fordman19762003
Jun 5, 2022 06:48 PM
RBerry9511
Feb 7, 2020 04:31 PM
93Sunplex
Feb 27, 2007 06:17 PM
Roger Davis
Jul 28, 2006 04:53 PM
tondalynn88
Feb 8, 2006 07:59 AM
