Trailer Harness Issues
Old Jun 12, 2026 | 11:18 AM
Rudeman's Avatar
Rudeman
I have a 2019 F-250. My trailer connection is up and down and it's very random. The typical scenario is I hook up nad head out; everything is fine. After and indeterminate time, my connection starts to deteriorate. I'll see tail light out warnings, first one side then the other. Then I'll get trailer disconnected warnings. Often, I'll get trailer disconnected, trailer connected, trailer disconnected warnings. I see these issues with different trailers.
Took it to the dealership and they could not find the cause nor replicate the issue.
Anyone out there have a similar issue with their rig?
Old Jun 12, 2026 | 02:57 PM
T. Banning's Avatar
T. Banning
Check your grounds!
Old Jun 12, 2026 | 02:59 PM
Rudeman's Avatar
Rudeman
Originally Posted by T. Banning
Check your grounds!
I did. They're good.
Old Jun 12, 2026 | 03:20 PM
Ford6.7ski's Avatar
Ford6.7ski
Might want to trace the wires from the truck seven pin to see where they connect to the harness.
I have a brand new truck and was surprised to see the seven pin connector receptacle above the tire for an add on TPMs system did not have a dust cap.
If something is added later, the connector may have been exposed to the elements weeks or years later.
You could also add an additional ground.
Ive had difficulty using a multimeter troubleshooting wiring. Sometimes the wire was held on with a single strand which ohmed out good, but couldn’t handle the load.
Old Jun 12, 2026 | 04:39 PM
jimzpsd's Avatar
jimzpsd
Hook up to a different trailer.......the loose connection may not be from the truck.
Old Yesterday | 05:53 AM
RV58's Avatar
RV58
7th Gear
Did you know that there is a Ford software update to the trailer brake controllers for 2019 F250's? I was having intermittent trailer connection issues (trailer connected / disconnected dash messages when the trailer was not hooked up) and after getting the update several months ago, no more dash messages. .
skidoorulz
Feb 15, 2026 04:48 PM
skidoorulz
16
Feb 13, 2026 07:04 PM
srkr
May 3, 2025 04:02 PM
nickshu
May 3, 2021 12:09 PM
muecker
Jan 11, 2019 10:03 PM
