Leaf spring question
Old Jun 8, 2026 | 07:54 PM
racsan's Avatar
racsan
What could of caused this? As far as I know its been this way since I bought it. Too bad I cant weld it- Am I right in thinking that I need to replace both sides? Spring code is D. I plan to stay with stock rate, dont need it to ride Like a 3/4 ton empty. Truck is a 89 F150 4.9/T18, has a 5-leaf spring pack. Broken spot is on passenger side front hanger.
Old Jun 8, 2026 | 08:38 PM
90project5.0's Avatar
90project5.0
You need to replace them! If it were me, I would be replacing the hangers also.
Old Jun 9, 2026 | 06:14 AM
wwhite's Avatar
wwhite
Looks like it was hit, bent the hanger and broke the spring.
probably from some heavy off roading, rocks and/or jumps.
Old Jun 9, 2026 | 09:13 AM
randy1011's Avatar
randy1011
I recently did mine. I agree with going with the originals. The ride will change if you don’t. Also agree about replacing hangers as well. It’s a bit of a pain, but just set aside some time and take it a step at a time. Lots of you tubes out there about it, so just watch a few. I did mine by myself and it was a complete pain. If able, get one other person to help, you’ll save yourself an awful lot of aggravation. this truck for sure took a bad hit. those things don’t “just break”, it had to have been badly stressed for that to happen. No worries, easy fix, just takes time and patience.
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by racsan
Am I right in thinking that I need to replace both sides? Spring code is D. I plan to stay with stock rate….
Correct. You need to replace both sides. Give Auto and Truck Springs (ATS) a call.
slick62
1961 - 1963 F100 Unibody
Dec 10, 2025 11:47 AM
willymakeit
Oct 1, 2023 08:59 PM
bayslayer
May 24, 2023 05:06 PM
plabath
Oct 26, 2020 06:29 PM
robert_l_ross
Nov 13, 2019 02:48 PM
