Front fuel pump issues
Old Jun 8, 2026 | 06:06 PM
mbooth236's Avatar
mbooth236
3rd Gear
Hello everyone,
I recently swapped the front fuel pump in my 90 f150 out for a new unit due to the gauge not working. I know it was probably a bad idea to swap the whole unit but I couldn't find a replacement sending unit for a reasonable price so here we are. The truck sputters and runs like crap on the front tank but runs great as soon as it is swapped to the rear (which still has the factory pump). After driving for a while I can switch the tank back to the front and have it run pretty decent under load but as soon as I turn the truck off and back on it runs like crap again. I'm planning on buying a fuel pressure tester to get readings from both tanks, but I would like to hear any suggestions you guys might have.
Thanks!
Old Jun 8, 2026 | 06:08 PM
90project5.0's Avatar
90project5.0
Originally Posted by mbooth236
Hello everyone,
Thanks!
verify fuel pressure, but I would lean towards warranty swap.
Old Jun 8, 2026 | 06:11 PM
mbooth236's Avatar
mbooth236
3rd Gear
This is actually a warrantied pump, probably should have mentioned that in the og post. The pump I warrantied had an issue with the check valve built into the pump and I could blow through the inlet. new pump doesn't seem to have this issue but still runs like crap.
Old Jun 8, 2026 | 06:15 PM
90project5.0
Welcome to the world of part store supplies these days..
Not what you want to hear, but it’s how it’s been.
Old Jun 9, 2026 | 06:53 AM
manicmechanic007's Avatar
manicmechanic007
I believe Bosch made those early pumps for ford
Look up one for a 1990 Ford Ranger for instance, and you will see a ton of pumps, most not worth a row of rat sh it
Look at Ebay item # 361092821497
It is a new Motorcraft pump that should be able to be put into your existing 1990 sender assembly
That is what I do these days, find a Ford pump and put it into the module assembly I need to fix
Old Jun 9, 2026 | 09:31 AM
1Butcher's Avatar
1Butcher
Many stores are meeting the demands of their clients. Cheap parts. Some day, people will demand good products and when that happens, they will make good stuff. If that day comes, I will be dead.
What brand is this pump? If it is cheaper than a good sensor, that is a problem right there.
FilmGuy
15
May 31, 2014 07:22 PM
jg09
13
Aug 3, 2013 07:50 PM
1988F1504x2
17
Dec 17, 2006 08:50 PM
Sailfish83
Electrical Systems/Wiring
31
Jun 23, 2006 06:43 AM
rednekf350
Nov 11, 2003 08:32 PM
