Rear Diff
Old Jun 7, 2026 | 07:58 AM
56fordguy's Avatar
56fordguy
Rear Diff
My 56 f250 has 4.56 rear gears with a y block and 4 speed. I would like to get different gears or different rear end. I get to 55 ish and it's just screaming at 3000 rpm. What are you guys using? I want to keep the 8 hole x 6.5.wheels. thanks
Old Jun 7, 2026 | 08:26 AM
pintoplumber's Avatar
pintoplumber
3000 won’t hurt your y block. I often spin mine up to 4500 on a shift. But I can see if you want to drive on a freeway maybe a change is in order.
Old Jun 7, 2026 | 08:33 AM
56fordguy's Avatar
56fordguy
Thanks for responding. I would like to go further distances. With things I read to change to 3.73 I need a different carrier and a thicker ring gear. I hear, a rear from a 67-72 f250 will work. Any other thoughts or ideas?
Old Jun 7, 2026 | 08:44 AM
56panelford's Avatar
56panelford
maybe this guide could help find you something to look for
https://www.blueovaltrucks.com/tech-...-door-sticker/
Old Jun 7, 2026 | 08:57 AM
56fordguy's Avatar
56fordguy
Ok thanks
Old Jun 7, 2026 | 09:24 AM
55F250's Avatar
55F250
AirForceVet
I put a 1968 DANA 60 with 3:73 gears in my 1955 F250, bolted right in with no problems. I'm running around 2000rpm at 45mph with the C6 transmission.
Old Jun 7, 2026 | 09:34 AM
52 Merc's Avatar
52 Merc
3000 isn't screaming. It's where these old engines were designed to run. You're just used to quiet, modern cars with double overdrive that barely idle at 80. Even my 460 lump in my 87 F250 with 3.54 gears runs right there at 70 on the highway. I will agree if your goal is to do 70 on the highway a gear change is in order. And yes, a Dana 60 from an F250 up to '72 is a bolt in and will make your life much easier. There are plenty of them out there. Find one with the gear set you want and go for it.
Old Jun 7, 2026 | 09:36 AM
56fordguy's Avatar
56fordguy
Great, so I take it you mean from a 68 f250?
What other changes did you have to make?
Tbounds02
Nov 6, 2023 08:25 PM
Bigred1995
WTB - Parts & other
Mar 6, 2018 09:38 AM
dohertycm
2009 - 2014 F150
Oct 23, 2015 05:28 AM
live4nascar
Modular V10 (6.8l)
Mar 21, 2006 06:43 PM
Christopher2
Jul 9, 2004 01:06 PM
