Spark plug Change Issue
Old Jun 12, 2026 | 04:48 AM
techrep's Avatar
techrep
what was the code ? did you get a new boot and spring with that new coil ? you should invest in a inexpensive DTC reader so you can troubleshoot.
Old Jun 12, 2026 | 09:47 AM
dkk's Avatar
dkk
P0303 and 304. Bought an Innova reader. Misfires. on cylinders 3 and 4. I suspect it's because of the stupid connectors not engaging and "clicking' as they're supposed to. I also learned that that can cause a could to be blown to the tune of about $70 bucks. Yes, I replaced all the boots, and springs when I did the plugs. I already replaced the coil on number 3 and expected to be good to go after clearing the code. Not happy with this thing right now.
Old Jun 12, 2026 | 02:13 PM
dkk's Avatar
dkk
coil to be blown. sorry
Old Yesterday | 06:32 AM
techrep's Avatar
techrep
you can edit your own post. pull the plugs on 3 and 4 and take a hard look at them, could have cracked porcelain, may have been dropped or could even be loose, I don't see where you mentioned using a torque wrench and what brand plugs were installed.
Old Yesterday | 07:58 PM
dkk's Avatar
dkk
Got it running right. After pulling number 4 I noticed that the spring was not in the boot, so somehow it fell out before I installed it and I didn't notice till taking it apart. I used Motor Craft SP548 X platinum plugs I bought from RockAuto, a trustworthy source for genuine parts I'm told. I used the Innova scanner after reinstalling everything and cleared the code and the check engine light went away. It runs very smoothly now as it should with fresh plugs. However, I am still concerned that not all of the connector clips are firmly clicked in place.
Considering buying these new connectors, which can be installed without splicing or butt connecting
V10man
Modular V10 (6.8l)
Mar 2, 2025 03:53 PM
JMKiser
1983 - 2012 Ranger & B-Series
Jun 8, 2024 07:50 PM
mtnxtreme
2015 - 2020 F150
Aug 8, 2022 09:28 PM
mantta
2009 - 2014 F150
Aug 6, 2014 06:55 PM
Mikey_23_ny1
Dec 14, 2013 11:12 AM
