A leprechaun and a priest. Joking aside I had a 5.8 on a stand and despite having the access and heat I still snapped four of them. Luckily I'm junking the heads. Needed heat and a 5' pry bar to pop the distributor too. Nuts.
Stainless is not a good idea
Galvanic corrosion occurs between it and aluminum, that will not be a problem with your exhaust manifolds but DON'T
The tensile strength is also lower than a regular steel bolt
Thread galling and seizing is also an issue
I have used them for looks before and regretted it
Right
Funny thing
The trans am race boys back in the day disassembled cars and engines and replaced every bolt in them between races
The Z-28 and the Boss 302's anyway, not sure about the Firebirds and the Javelins
I have PSE studs in my Boss block, heads and mains (Pro Stock Engineering) IIRR
Another thing to watch on Youtube is one rod bolt popping off and laying on the floor of SME engines shop (Steve Morris Engines)
One flat out broke just sitting there torqued
Sort of like a car salesman walking past a BMW with a yellow tie on, and the side window shatters
Watch "this is insane... what's with all of these bolt failures???" on You tube put out by steve morris racing
I think some of that high dollar stuff is made in China
When I start putting my parts together on my 408w, I will address the seized bolt issues on the intake/front cover. Not certain why, my goal is never to take this apart in my lifetime. That said, I really would not get anything stainless for the internals of an engine and I don't want to use stainless that will gall.
I did buy ARP stainless studs for the exhaust manifolds. Mostly because I am the one building the headers and I am expecting problems. I know about regular stainless so that was not an option. I do know the Germans [mostly Mercedes because BMW uses exhaust hardware that rusts too easily] use something that does not seize. Heck, the older turbo diesel hardware was 10x the price of a standard bolt. I can only assume is was some type of inconel.
If I was a builder, it would be a real issue if I had rod bolts breaking while building the engine. You might as well close the doors.
yeah, I see that ARP makes stainless intake manifold bolts and had me wondering if that would be smarter to avoid this again.
So.......Do you plan on doing this again?
I have not decided what I will be doing, but the time will come when I will make a decision. I will be buying new bolts because I know the core engine bolts were broken and way to ugly to reuse. ARP is not cheap and their stainless is over the top. I debated using their studs for the exhaust manifold, mostly due to costs and my feelings that stainless is really not that good [galling]. After enough research, I think I made the right decision. Time will tell.
I don't think the factory did anything to prepare the new bolts in and torque it down. I think if you used anti seize or other products, the bolts would not seize or not seize anytime soon. Part of the reason that I believe they seize is because of the cheap trashy cast aluminum they used. Combined with the cheap bolt hardware, it's good enough for a few years, but not a few decades. My feelings right now is I will not be using stainless for the intake bolts.
I’d rather not spend $50 on ARP stainless bolts so I’m leaning toward using original grade bolts covered in antiseize. I use antiseize on almost every single screw, nut and bolt I ever take loose and I feel like this has always been worth the extra step for whomever works on it next. I would use antiseize regardless of the bolt material.
I don’t plan on having the intake off again, but stranger things happen. These intake bolts are really puny as well which I don’t particularly like
When I put things together, I tend to think it's the last time. Sadly this is not always the case.
When I built my E4OD. I had it out 4 times and every time was suppose to be the last time. I was somewhat expecting that because of all the mismatched parts I used to make in mine. I hated every time I came to the conclusion I had to take it out again. Fortunately, I have a lift in my shop, but still I hate removing anything big.
