intake manifold bolts
Old Mar 28, 2017 | 09:11 AM
old farmer's Avatar
old farmer
Quick questions.
Do some or all of the intake bolts on a 302 need thread sealant? Do they pass through water jackets?
Thanks.
Old Mar 28, 2017 | 11:53 AM
Glaser67's Avatar
Glaser67
Originally Posted by old farmer
Quick questions.
Thanks.
I can only speak about the 302 EFI intake, but no. I used a little anti-seize when I bolted mine on. I only used thread sealant on the shorter, lower head bolts.
Thanks,
-Glaser67
Old Mar 28, 2017 | 12:53 PM
Beanscoot's Avatar
Beanscoot
The early engines had thin aluminum washers under the heads, I think Ford might have been concerned about vacuum leaks from there.
Old Apr 1, 2017 | 01:05 PM
baddad457's Avatar
baddad457
None of the 302 intake bolts pass through a coolant passage. And none pass through an intake passage to create a vacuum leak. There is a possibility of getting oil seepage up the bolt from the lifter valley, but I've never seen this happen. The only bolts that need thread sealer are the lower head bolts on 1985-up blocks and the four waterpump/timing cover bolts that are on top/bottom of the two coolant ports in the front of the block. Plus the flywheel/flexplate bolts on the later model crankshafts. The holes these thread into go through the rear flange into the crankcase area.
Old Feb 8, 2018 | 11:34 PM
DieselHardware's Avatar
DieselHardware
Is there anything special about the factory bolts? Having a hard time finding the intake manifold bolt kits in stock locally. Wondering if I can just grab the right size bolts at a local bolt place and use them?
Old Feb 9, 2018 | 08:13 PM
baddad457's Avatar
baddad457
They're all 5/16NC. I don't know the length off hand. I can look in my stash tomorrow and measure them
Ron Pauly
May 2, 2018 07:42 AM
annaleigh
Jun 8, 2017 05:34 AM
SS502MC
May 25, 2016 04:38 AM
rdweathers
Apr 6, 2011 12:50 PM
skuteman
Jan 8, 2005 04:02 AM
