Sponsored by: Auxito
2001 supercrew problem areas?
Old Dec 10, 2003 | 10:25 PM
91f3507point3's Avatar
91f3507point3
going to buy a 50,000 mile 5.4 lariat tomorow. private sale, no warentee. 20k. are there any trouble areas this truck is prone to? i saw another that was leaking from the pinion seal, this is supposed to be lady driven, garaged, would really appreciate any help. thanks guys.
Old Dec 10, 2003 | 10:44 PM
91f3507point3
ps
saw some oil covering the pass side valve cover, i am hoping this was just spilt while changing or topping off, or is there some common problem here?
Old Dec 10, 2003 | 10:52 PM
superrangerman2002's Avatar
superrangerman2002
Welcome!
From what I understand there is a slight weakness in the passenger rear head on the 5.4L motor.... That was just from a local Ford tech I know....wether there's any truth to it I don't know.
I think that Racerguy could answer this question quite well, let's hope he sees this post.
Old Dec 11, 2003 | 09:27 AM
Racerguy's Avatar
Racerguy
The leak is usually the head gasket. It is quite common. The valve covers gasket very rarely leak so it could be oil from filling it. Take a close look underneath in the area above the starter and you should be able to tell if the head gasket is leaking.
Old Dec 13, 2003 | 07:10 PM
91f3507point3
bump, any other chronic problems i need to look out for?
Old Dec 14, 2003 | 09:32 AM
Racerguy's Avatar
Racerguy
Can you get any service records for the truck?
If it hasnt been done you might want to think about new spark plugs and fuel filter soon. I would probably check the front end to make sure the balljoints are tight. Make sure the transmission shifts ok. If it shudders at all it probably just needs the oil changed. These trucks dont have all that many chronic problems so you probably dont have much to worry about
Old Dec 14, 2003 | 02:15 PM
LxMan1's Avatar
LxMan1
The price is a little high for the miles, I bought mine,it is a supercab not a supercrew, with 26,400 miles with the remainder of the factory warranty for the same price. Try to find a good lease return, these are usually a better deal.
Jimmy
Old Dec 14, 2003 | 05:54 PM
91f3507point3
ist a supercrew lariat, looked dry undernieth, 4x4, gonna buy it tomorow.
thanks
skymonkey
North Carolina Chapter
21
Jun 14, 2007 08:57 PM
gearheadz80
Wisconsin Chapter
25
Jun 8, 2007 05:12 AM
FTE Herman
Indiana Chapter
18
Jan 20, 2005 09:34 PM
Craigwell
Nova Scotia
18
Nov 26, 2004 02:41 PM
Cognito
Michigan Chapter
Nov 27, 2002 05:48 PM
