Rough Bouncy Ride
>I DO NOT reccommend over inflating your tires, nor do the
>manufacturers. It can result in failure and lead to
>possible injury.
The manufacturer is NOT recommending overinflation. I think the confusion comes from thinking of Passenger car tires (tires that start with P in the size). P tires give a max inflation pressure. The Light truck tires (tires that start with LT in the size) that come on our trucks only have a max weight. If you don't believe me, go check some tires. LT tires will say something like "max load 3415 lbs at 80 psi cold". What that means is that in order to carry the max rated load of 3415 lbs, you need a MINIMUM of 80 psi. According to Firestone, you should put 90 psi cold in that tire if you are at max load and plan on extended driving at 70 mph.
Harald
2000 F350 4x4 CC DRW V10 4.30ls Lariat LWB.
Firestone Ride-rite airbags, Rancho RS9000 shocks and Torklift Superhitch.
1998 Alpenlite Pendelton 11'10" camper held on by Torklift tie downs.
Remove I_HATE_SPAM_ from email address to email me.
