block ID
Old Dec 10, 2003 | 08:23 PM
bluetop king's Avatar
bluetop king
block ID
This is a part number off a block. What engine is it?
D7TEA3B
THis is the cast number
1L10
Old Dec 11, 2003 | 11:51 AM
bubbaf250's Avatar
bubbaf250
It is a late production 351M/400, with a casting date (1L10) of November 10, 1981. It was manufactured during the last model year (1982) that the 351M/400 was produced.
Since the same block was used for both 351M and 400 engines, you have to identify the crankshaft to determine which one it is.
Check this page for more info about the crankshafts:
http://home.earthlink.net/~bubbaf250/parts/parts02.html
Old Dec 11, 2003 | 12:13 PM
ranchero77's Avatar
ranchero77
bubbaf250, about your "can't use a wire in the spark plug hole".
if you measure the stroke and get 4" you have a 400 or a stroked original 351M.
if you get 3.5" you have a 351M or a destroked originally a 400 (which someone should be commited for ever doing).
so what I'm getting at, I agree this is not for measuring the authinticity of the original intent of the block but aren't you getting the answer for what is it now?
Old Dec 11, 2003 | 05:31 PM
ctfuzzy's Avatar
ctfuzzy
Originally posted by bubbaf250
. . . http://home.earthlink.net/~bubbaf250/parts/parts02.html
Please pardon me for interrupting guys, but this is a very cool web site bubbaf250.
Thank you.
(and go finish the engine recipes, please)
Old Dec 11, 2003 | 06:28 PM
bubbaf250's Avatar
bubbaf250
ranchero,
The linked page refers to measuring crankshaft stroke, not the block. The issues are the same, regardless of the origin of the block.
The problem is that there is no practical way you can get a reliable measurement. I have seen several cases where measuring with a coat hanger yielded less than 3.5" with a 400 crankshaft.
ctfuzzy,
Thanks for the kind words.
I have lots of data, but little time to do much with it right now. For two years, I've been saying that I'll get to it in the next few months.
Old Dec 23, 2003 | 06:48 PM
rangoonred67's Avatar
rangoonred67
I cant get the # off the block but I got a # off the exaust maniflod it reads D2OE94340BA. \
THE GUY I GOT THE TRUCK FROM SAID THE BLOCK CAME FROM AN EARLY 70'S PASSENGER CAR.
can someone help????
Old Apr 7, 2009 | 07:27 PM
tombuckaroo_ga's Avatar
tombuckaroo_ga
wHEN i PULL THE CRANK WHAT SHOULD THE CRANK CODE BE FOR THE 400
66BlueOval
15
May 9, 2025 03:58 PM
dentside owner
May 13, 2017 03:34 PM
rh428wf
Jul 9, 2011 06:04 PM
jacob_9249
Jul 26, 2008 08:04 AM
TCTOOL
Dec 20, 2001 12:43 AM
