Performance drive shaft
Old May 2, 2026 | 12:38 PM
beartracks's Avatar
beartracks
Anyone running an aluminum drive shaft. Considering one. I think the last person I let work on my truck forced the wrong Ujoint into the rear drive shatt. Vibration starting about 60mph. I've eliminated everything I can think of but it so here we go (hopefuflly not down the rabbit hole.) Going to replace the entire drive shaft as I'm very tired of chasing this problem.
Old May 2, 2026 | 05:41 PM
DaveMcLain's Avatar
DaveMcLain
Most salvage yards have a bunch of used drive shafts usually inside of an old school bus or truck body. With a tape measure you can sort through the pile and find what you need. You might find an aluminum shaft in the correct length with the right U joints to work in your application. I don't see any real reason to get tricky with a driveshaft.
Old May 2, 2026 | 06:43 PM
440 sixpack's Avatar
440 sixpack
I agree I'd keep it simple and cheap.
Old May 2, 2026 | 06:49 PM
Rubiranch's Avatar
Rubiranch
$$$$$$ and no gain IMO.
Old May 2, 2026 | 07:13 PM
DaveMcLain's Avatar
DaveMcLain
My friend Wes ran 5.70's in the 1/8th in his Ford pickup for hundreds of passes with a driveshaft made with one end from a Caprice and the other from an Astro Van. He tried a fancy chrome moly driveshaft and wadded it up in 2 passes. Your mileage may vary...
Old May 3, 2026 | 10:19 AM
beartracks's Avatar
beartracks
Well I'm stuck using a t400 slip yoke and 1350 Ujoints (GearVenders and Currie TruTrak). So it's going to be custom made, don't trust what I have now.
Old May 3, 2026 | 12:58 PM
Pickupmanx2's Avatar
Pickupmanx2
I would see if you have a driveline/driveshaft shop locally... a few yrs ago, my Excursion decided to spit the d/s out after a gear change (long story, in the Ex forums) got used Excursion one, had it balanced, still had vibration, new u-joints, everything checked out saying it should be fine, older mech, (the owner of the shop actually) suggested we lengthen it 2" and get it seated further in the transmission, lengthened it, rebalanced, badda boom, badda bing, smooth as can be. All that to say, are you sure all your insertion lengths are solid as is your slip yoke..?
Old May 3, 2026 | 01:56 PM
beartracks's Avatar
beartracks
The only driveshaft shop in town is the one that screwed up the last one.
Old May 3, 2026 | 02:06 PM
DaveMcLain's Avatar
DaveMcLain
PEM in St Clair MO does custom driveshafts of all types. I had them shorten and rebalance the driveshaft in my truck when I switched from a C6 to an E4OD.
Old May 3, 2026 | 02:55 PM
beartracks's Avatar
beartracks
I'm currently emailing with Action Drive Shaft for a price. PST ghosted me after a couple of questions. I'll keep PEM in mind.
Old May 4, 2026 | 12:28 AM
Pickupmanx2
Sorry to hear that... damt... good luck with finding a place that'll do it, sheesh, used to be nary an issue.
Old May 4, 2026 | 09:03 AM
beartracks's Avatar
beartracks
At one time there were three good driveline shops in town. Now the front of one looks like a taco shop and I never heard of them. The other is an old shed building with a broken down cement mixer and a dump truck taking up all the lot.
Old May 6, 2026 | 09:15 AM
somethingclever's Avatar
somethingclever
If you are going to have one made, I would just get steel....aluminum wouldn't be worth the extra money in your application.
68horses
Dec 21, 2014 07:11 PM
gpbullock
Jul 11, 2009 01:12 PM
phazer
1997 - 2003 F150
Jan 25, 2007 08:44 PM
harold31816
2004 - 2008 F150
17
May 25, 2004 01:20 PM
