Sponsored by: Auxito
front drive shaft
Old Jan 22, 2007 | 05:16 PM
phazer's Avatar
phazer
front drive shaft
I have a 1998 f-150 4x4 super cab. The splines are gone on my front drive shaft causing alot on vibration when in four wheel drive. I was wondering if the drive shaft from a 1995 f-150 would fit my truck.I know that the ends are different,but if the u-joints are the same size I could use my own ends.
Old Jan 25, 2007 | 05:09 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
....bump.....
Old Jan 25, 2007 | 07:18 PM
Ultramagdan's Avatar
Ultramagdan
Why wouldn't you just get the correct shaft? Sounds like a lot of work otherwise.
Old Jan 25, 2007 | 08:25 PM
phazer's Avatar
phazer
found out that the pre 1997 shaft won't fit.too long.the reason i wanted to use this shaft was that i could get one for $80.00 compared to almost $400.00 for a 1998 one.MONEY TALKS.
Old Jan 25, 2007 | 08:44 PM
Ultramagdan
400 sounds a bit high. I would try other options too.
welder309
2009 - 2014 F150
Oct 25, 2010 06:36 PM
shorty2tall
Sep 11, 2010 11:58 PM
tomoto
Jan 21, 2006 07:59 PM
73-79P/ULover
21
Nov 9, 2003 11:49 AM
