1978 - 1996 Big Bronco
ABS light comes on
Old Jan 12, 2004 | 05:29 PM
4xfordbronc's Avatar
4xfordbronc
Does your speedometer bounce around also? Mine does and when I replaced the VSS unit on top of the housing my speedo still jumps around and the light comes back on when the speedo jumps around the 70 mph range.
Gabe
Old Jan 12, 2004 | 05:57 PM
meyerja's Avatar
meyerja
That's a wierd one. Almost sounds as if you may have a bad connection on the back of your instrument cluster. If I remember right there is 2 or 3 push in wiring looms on the back of the IC. They may be loose or corroded. Sounds electrical.
run6.0run
Feb 28, 2012 04:32 PM
Waff78
1997 - 2003 F150
Dec 31, 2008 01:18 PM
Gmeanie
May 15, 2008 01:27 PM
cratemotor
1983 - 2012 Ranger & B-Series
17
Dec 3, 2007 12:23 PM
ketchup2me
May 5, 2005 06:06 AM
