Flashing OD light
Old Apr 19, 2026 | 05:02 PM
Zackm51's Avatar
Zackm51
4wd High
Flashing OD light
Alright so I’m a little stumped I’ve been chasing this problem for a wile now I have a 94 7.3 idi factory turbo e4od. When I start to drive the truck it will shift fine for a couple miles then go into limp mode. It’s got a fresh trans and torque converter in it and I’ve changed all the sensors associated with the transmission. When I pull the codes I get a 10 followed by a 11 and from what I’ve read that means everything is ok. The only other thing I have read about is these trucks not liking LED lights, it has a flat bed on it with some cheap Amazon trailer lights in it. Could this be my problem??? Also I have the factory 3rd brake light in and it works as should.
Old Apr 19, 2026 | 06:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the OD light is flashing, there is at least one code stored. Getting a 10 and then an 11 means you're missing the first set of codes. The 10 is a separator between the first and second set of codes.
LED lights can fool the PCM into thinking the brakes are applied when they are not. All this can do is prevent the torque converter clutch from locking. This will not set a code, and it will not put it in limp mode.
Old Apr 20, 2026 | 11:27 AM
Zackm51's Avatar
Zackm51
4wd High
thanks for the reply sometimes the torque converter won’t lock then will randomly lock up and act fine with no flashing od light
Old Apr 20, 2026 | 12:54 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Replace the LED's in the bed, or try adding some load resistors.
Old Apr 20, 2026 | 01:35 PM
Zackm51's Avatar
Zackm51
4wd High
where would you tie them in at?
Old Apr 20, 2026 | 01:57 PM
FORDF250HDXLT
Here ya go.
Well, I guess he's installing them for turn signals, not brake lights like you need, but same deal. They're easy to install.
Old Apr 20, 2026 | 03:04 PM
Zackm51's Avatar
Zackm51
4wd High
Here ya go.
https://www.youtube.com/watch?v=ADKjG3Z2L5w
thanks for the info
fireguync
May 31, 2023 03:22 PM
Patches3327
Nov 12, 2018 11:03 PM
fordman.cab3
Jan 27, 2015 10:12 PM
ldfry001
Feb 6, 2014 07:11 PM
clemensfield
Jun 27, 2013 09:06 AM
