Away from home with issues
Old Feb 6, 2014 | 09:11 AM
ldfry001's Avatar
ldfry001
I have a E99 F250 7.3 4x4 and all of a sudden my 4x4 and low range lights come on and stay on even though it's in 2wd. And now the OD light it's blinking. Does anyone have any idea what this is? Any help would be appreciated, I'm about 4 hours from home working so I'm hoping it's nothing major.
Thanks
Old Feb 6, 2014 | 09:28 AM
t.scottNDU's Avatar
t.scottNDU
Hopefully Mark K. will chime in, but I think he's going to tell you there's about 50 different trans faults it could be and that you won't find out without a scan tool.
Don't mind me too much, I know the bare minimum about these transmissions.
Old Feb 6, 2014 | 10:04 AM
ldfry001's Avatar
ldfry001
I just turned the truck off then started it and drove it and the OD light wasn't flashing but the 4x4 lights were still on. Then I turned it off again and restarted it and the OD light and 4x4 light are now off. I don't want to say problem solved because I didn't change anything so I'd still be curious as to what causes the lights to come on.
I know the vss can cause the OD light to blink cause I just changed it not to long ago
Old Feb 6, 2014 | 10:34 AM
HKusp's Avatar
HKusp
Where are you? Maybe one of us with a scanner isn't too far from you and we can get the codes read and go from there.
Old Feb 6, 2014 | 11:01 AM
ldfry001's Avatar
ldfry001
I am currently in Chillicothe Ohio. I'm leaving here this afternoon and heading back home around Louisville ky
Old Feb 6, 2014 | 03:31 PM
Tugly's Avatar
Tugly
Chaffed wire harness on the steering column?
Old Feb 6, 2014 | 03:47 PM
ldfry001's Avatar
ldfry001
I will look for a chaffed wire. Now my 4x4 will not work.
Old Feb 6, 2014 | 07:11 PM
bdpotts's Avatar
bdpotts
after three or four miller lites i'm thinking plug connection? disconnect/reconnect battery terminals? operate OD switch and 4x4 selector switch and see what that gets you?
Jaime74656
Mar 10, 2015 03:29 PM
gametime2387
Feb 4, 2010 10:17 AM
Daugh20
1997 - 2003 F150
Dec 18, 2009 11:00 AM
fishel74
Escape & Escape Hybrid
Apr 2, 2008 04:00 AM
lildebo
Mar 2, 2008 11:48 AM
