E4OD problem
Old Apr 17, 2026 | 01:06 PM
kingary49's Avatar
kingary49
4wd Low
E4OD problem
93 F150 XLT, .351W, stopped moving, fluid poured out. Could it be torque converter? Clueless.
Old Apr 17, 2026 | 01:16 PM
90project5.0's Avatar
90project5.0
Where did it pour out from? It could be pump seal, TC, cooler lines, crack in the case.
Old Apr 17, 2026 | 02:53 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it could be the torque converter. It could be several other things, too.
Old Apr 17, 2026 | 03:26 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Most often when this happens, the front pump/converter seal has failed. Very common after sitting for long periods of time. It will run out of the converter cover drain tube. Once it looses enough fluid of course, you wont have any working gears. You don't want to start the engine again or you could damage the pump. Sometimes, though a bit less often, the bushing walks forward right behind that seal, and this causes all the fluid to pour out because it blocks the return hole.
If this is where the leak is, you'll have to pull the trans to replace the bad seal, bushing and or pump, depending on what happened.
Maybe you got lucky and just blew a trans line or something. You'll have to show us a pic of where the fluid came from.
Old Apr 19, 2026 | 12:30 AM
AuroraGirl's Avatar
AuroraGirl
overheat.sounds like he was driving, lost gears, and it was puking. thats an indicator either its not cooling or its not locking up or its busy shifting frequently and slipping lots during so
kinked cooler line, blocked cooler.. etc
Old Apr 19, 2026 | 12:13 PM
kingary49's Avatar
kingary49
4wd Low
Leak
My son was driving when this happened, pulling a laded trailer. Waiting on him to get my truck home so I can eyeball it. Apologize for jumping the gun. Y’all have given me things to search for. Thank you! Will definitely be in touch.
Old Apr 19, 2026 | 12:42 PM
FORDF250HDXLT
You did the right thing. You don't know what you don't know. You learned not to start the truck, and especially not try and drive it without first putting some ATF back in; which is Mercon 5 by the way.
hjartland
Nov 1, 2023 12:33 PM
Scrappy507
Jun 26, 2022 12:24 AM
kjjr20
Aug 10, 2014 05:08 PM
RawPower
Feb 21, 2006 01:22 AM
swenny
Feb 5, 2004 08:48 PM
