T/C seating E4OD
Old Oct 30, 2023 | 06:04 PM
hjartland's Avatar
hjartland
T/C seating E4OD
Torque converter seating into an E4OD. Is this as deep as it goes?
It seemed to click the 3 times you guys talk about.
1993 F-150 4×4 XLT 351W E4OD
Old Oct 31, 2023 | 07:28 AM
manicmechanic007's Avatar
manicmechanic007
That looks good
Just make sure the torque converter rattles during the install
That means the torque converter is loose in there and must be pulled up forward to the flex plate when bolting it up
If you start all the bolts or nuts on the studs, the torque converter will rattle back and forth meaning (indicating) the front pump is not on a bind
Good luck
Generally, if you cannot get your fingers back behind the converter, it is installed all the way
Old Oct 31, 2023 | 04:15 PM
hjartland's Avatar
hjartland
Nice
Thanks. I did notice it can be wiggled up-down, left-right. Had been wondering if that was normal.
I have not drained it since it was out. Do I need add any ATF? If so, what kind?
TIA
Old Nov 1, 2023 | 05:59 AM
manicmechanic007
Up and down and side to side some is okay because the hub is not mated to the crankshaft center hub yet
Use Mercon V (2 reasons) because you will have a hard time finding old Mercon that was not synthetic like the V is
And V is better fluid (longer lasting)
Old Nov 1, 2023 | 12:33 PM
hjartland's Avatar
hjartland
Thank you. I'll grab some today.
mstrebe
Apr 12, 2023 09:19 PM
sandymane
Apr 12, 2023 01:34 PM
Blown349
Ford Truck Parts for Sale
Oct 7, 2013 07:57 PM
Greg5OH
May 26, 2012 06:49 AM
Big95Bronco
Jun 4, 2008 10:17 PM
