Coolant pressure
Old Apr 11, 2026 | 02:50 PM
Hartwig's Avatar
Hartwig
I have 3D print files for installing the pressure gauge in the footwell (I can send you the file if you’d like).
I’d also like to point out the following: we’re seeing coolant pressures of up to 18 psi (depending on the bottle cap) and coolant temperatures of up to 105°C / 221°F in the system.
If there’s damage to the head gaskets or cylinder heads, it might be even higher. I’m not sure how well a simple rubber hose with a clamp would hold up here.
That’s why I use thin measuring hoses from the hydraulic industry (pressure-resistant up to well over 4000 psi, stable, and easy to route).
I don’t even want to imagine what would happen if the pressure gauges were mounted near the steering wheel and the hose slipped off the gauge, causing hot steam and hot coolant to escape.
That’s why I have the pressure gauge installed in the footwell.
You can get a good 0-20psi stainless steel gauge in a hydraulic shop/store.
Old Apr 12, 2026 | 10:50 AM
Fuzzpuss's Avatar
Fuzzpuss
Thank you, Hartwig, but I was talking about the hose as a temporary way of monitoring while driving.
I would like to know more about these hydraulic hoses, for use with other mechanical pressure gauges.
Old Apr 12, 2026 | 03:29 PM
Hartwig's Avatar
Hartwig
These hoses are designed for pressure measurement in hydraulic systems.
https://www.kramp.com/shop-de/de/p/m...t-2x--MPSW2000
Old Apr 13, 2026 | 07:51 AM
Fuzzpuss's Avatar
Fuzzpuss
Thank you, Hartwig!
8lug
Jul 9, 2025 06:51 PM
oxt127
Jan 2, 2016 07:54 AM
ultrasks700
Nov 19, 2015 08:56 PM
tjmike
Jan 30, 2015 10:15 PM
DieselVol
Jun 11, 2013 03:21 PM
