VIN Decoding Help Please
Old Apr 2, 2026 | 08:00 PM
Adventurevan's Avatar
Adventurevan
Trailering
Hello could someone please help decode this VIN? I believe it to be a 71 F100. Any additional information would be appreciated.
Old Apr 2, 2026 | 08:32 PM
85e150's Avatar
85e150
Here you go. That plate is a little hard to read, so please confirm that I read it right on all the characters.
F11 = F100, 4x4
Y = 360 2V FE gas V8
R = San Jose Assembly Plant
L02362 = 1971 numerical series, February 1971 production
131 = 131 inch wheelbase
MV (??)
M = White
V = Dark Green (NOTE this is corrected)
F110 = F100, 4x4, 5600 GVWR, "Except State of PA".
6 4
6 = Light Green/Medium Green Vinyl
4 = With the numerical first digit--Custom Cab with styleside pickup box. Cab parts cataloged as "81", behind cab "99"
A = New Process model 435 four speed transmission
08 = Ford (9 inch) 3,300 lb capacity rear axle, 3.50 ratio
No front axle code but it's probably a Dana 44 and should have identifying info on it.
5600 = 5,600 lbs GVWR
170 4100 = 170 certified net HP @ 4100 RPM
742054
74 = Seattle District Sales Office
2054 = Special Order Number
Old Apr 2, 2026 | 09:53 PM
Adventurevan
Trailering
Thank you!
I'm interested in the paint color MV. The letters are definitely MV and not MY.
Is there a color code that correlates with V? The original roof color is a green color.
Also, does the color white M have any other detailed information other than just "white"?
Old Apr 2, 2026 | 11:43 PM
85e150's Avatar
85e150
Sorry, I had MV down but gave you MY. It's corrected above, and V was Dark Green. Makes more sense.
As to M shows only "white" in the Shop Manual and in the Master Parts Catalog.
The part number in the MPC is AE60 1619-A, and the Canada code is M1J 1619, and the "M30J/M32J Spec No" is 1619-A.
The other white would have been code "C", for "Special White" in the Shop Manual or "Pure White" in the Master Parts Catalog.
Old Apr 4, 2026 | 03:23 PM
Adventurevan
Trailering
Thank you for your help.
According to the PPG color chart M = Wimbledon White and V = Mallard Green.
MattB11
Large Truck
Jul 27, 2025 07:39 PM
drknight_fnp
Large Truck
May 10, 2024 06:11 PM
Big Kaz72
Large Truck
Dec 7, 2022 07:20 PM
J_Remy
Jun 29, 2021 03:12 PM
