Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Vin decode help
Old Jul 27, 2025 | 03:01 PM
MattB11's Avatar
MattB11
1st Gear
Vin decode help
hard to tell but the serial is F60CK222728
Old Jul 27, 2025 | 04:06 PM
asavage's Avatar
asavage
FTE Community Team
Old Jul 27, 2025 | 07:16 PM
85e150's Avatar
85e150
Welcome to FTE! Thanks to @asavage it will take far fewer hours to decode. Where were you in '62?
F60 = F600
C = 292 2V Medium Duty Ford Y-block, 135 Certified Net HP @ 3800 RPM
K = Kansas City Assembly Plant
222728 = 1962 numerical series, October 1961 production
156 - 156 inch wheelbase
L = Dark Green
F600 = F600, 17,000 lbs GVWR
F = Borg Warner T98A four speed transmission. Synchro in 2, 3 & 4.
F1 = Eaton model 13802 two speed rear axle, 15,000 lbs capacity, 5.83 / 8.11 ratios
No front axle code. Given the GVWR and rear axle capacity, it's probably a Ford, 4,500 capacity, no power steering. There should be identifying info cast into the axle, possibly on the passenger side, back of axle.
17000 = 17,000 lbs GVWR
135 3800 = 135 Certified Net HP @ 3800 RPM, as stated in the MPC for '62.
0414
This appears to be the special order number, with no 2 digit District Sales Office number showing.
Old Jul 27, 2025 | 07:39 PM
85e150's Avatar
85e150
Check the links and postings here:
https://www.ford-trucks.com/forums/8...l#post19892682
Your truck could have the Firestone RH 5 degree "widow maker" wheels. No one will work on them, and they can come apart under certain circumstances, or sometimes just for no apparent reason--although that's usually right after you work on them.
Stay out of the line of fire when airing up. The rear duals will pop out and get you. The fronts pop into the frame and brake lines.
Good luck!
jryan23
Large Truck
Oct 28, 2023 07:09 PM
jryan23
Oct 24, 2023 03:19 PM
Big Kaz72
Large Truck
Dec 7, 2022 07:20 PM
J_Remy
Jun 29, 2021 03:12 PM
