Help with shift column/ shifter
Old Mar 30, 2026 | 09:35 AM
MDHunter's Avatar
MDHunter
Hopefully the smart guys here can help me with a couple of issues.
2000, F250 Super Duty
A couple of months ago, my steering column shift tube broke, I attributed this to the shift cable which was heavily corroded and extremely stiff.
I replaced the shift tube with a Dorman.
I replaced the shift cable with a Motorcraft
Doing all this I buggered up the shift interlock solenoid; replace with NAPA part.
Now to the issues:
1. While in park, I have to push the shift the shift lever up to be able to remove the key and to start the vehicle.
2. I can start the vehicle without pushing on the brake pedal.
Any help will be greatly appreciated.
Respectfully
Mike
Old Mar 30, 2026 | 10:43 AM
z31freakify's Avatar
z31freakify
You have to adjust the shift cable down on the transmission.
Old Mar 30, 2026 | 11:24 AM
Pikachu's Avatar
Pikachu
With transmission in the neutral detent, and the wheels blocked, align (or replace if it's still hard to shift) the DTRS, digital transmission range sensor.
Old Mar 30, 2026 | 12:00 PM
MDHunter's Avatar
MDHunter
Gentlemen, thanks for the input, adjusting the shift cable at the neutral safety switch was already done, it's maxed out to one side. And it doesn't address the interlock switch issue.
Respectfully
Mike
Old Apr 1, 2026 | 12:32 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Just guessing here but...
Follow the cable from trans up to shifter. There is a plastic stop where the shift cable housing is held that tends to break. There are
metal replacements metal replacements
Good luck!
Old Apr 1, 2026 | 10:32 AM
Eman85's Avatar
Eman85
You had the shift tube break? Are you meaning the aluminum rod that runs the length of the column and held by 2 saddles and bushings. If the replacement part is Dorman that might be the first suspect I'd question. The having to move the shift lever up to remove the key, I'd look in the shift lever part of the column for slop/wear.
I don't understand the stepping on the brake pedal to start, the interlock is to make you step on the brake to move the shift lever from Park.
The part linked above is for the shift indicator cable, the plastic piece breaks easily from age but shouldn't affect performance.
Old Apr 1, 2026 | 10:49 AM
MDHunter's Avatar
MDHunter
Yes, it was one of the ears on the tube, too much stress from the corroded cable. I do suspect the dorman part, I have a new Motor craft part on hand. I also know that the shift lever interrupt switch is not working properly as I can start the truck and shift w/o stepping on the brake.
Old Apr 1, 2026 | 10:53 AM
Pikachu's Avatar
Pikachu
You should be able to start it without the brake being pressed, but not shift out of park.
73F100_TX
Aug 21, 2022 11:07 AM
Thomas Hutchins
1997 - 2003 F150
Aug 25, 2014 09:49 PM
michaelskerrett
Jun 25, 2014 11:18 AM
Daviddc114
Mar 20, 2011 08:30 PM
66_in_ky
May 6, 2010 09:25 PM
