Noise when applying brakes
Old Mar 27, 2026 | 06:49 PM
dh_meyer's Avatar
dh_meyer
I recently noticed a noise that occurs when I apply the brakes on my 2012 F150 Lariat 4WD (127,000 miles). It sounds like more of a 'groan' and seems to be coming from the front of the truck. After I've driven a few miles, when I apply the brakes, the groan seems to have gone away.
I had the following front brake work done 9 months/5,000 miles ago: new calipers, rotors, pads, fluid flushed/bled, and some hoses replaced.
My 4WD worked fine all winter - not sure if this eliminates an IWE issue or not.
AI has suggested a brake booster valve, misc rear brake issues, among other things.
Any suggestions ?
Old Mar 28, 2026 | 08:27 AM
rbentnail's Avatar
rbentnail
It's really easy to install brake pads incorrectly, they go only 1 way. Wrong and they're noisy.
Old Mar 28, 2026 | 11:28 AM
dh_meyer's Avatar
dh_meyer
I should have mentioned that the brake work was done at a Ford dealership ............... I know, could still have been done wrong.
But would an improper installation just start making noise 5000 miles later ?
Old Mar 29, 2026 | 09:38 AM
steve(ill)'s Avatar
steve(ill)
you can guess all day long... your never going to know untill you jack it up, remove the wheel and look / test / check.
berick
Nov 4, 2012 09:54 PM
PsD007.3
Sep 7, 2009 09:31 PM
fordguy4life
1997 - 2003 F150
Sep 18, 2007 12:19 PM
mbnv992
Nov 30, 2004 11:37 PM
Donald Rohret
1983 - 2012 Ranger & B-Series
Aug 14, 2004 04:22 AM
