Crank No Start
Old Mar 24, 2026 | 11:57 PM
Garrett357's Avatar
Garrett357
2nd Gear
Crank No Start
I have a 96 F250 that will not start. I’ve installed fresh batteries. I’ve installed a new IPR a new CPS, a new relay for the IDM and new valve cover gaskets with integrated wiring harness. I think I’ve narrowed it down to something electrical. I get 12 V to the harness outside the valve cover, but I do not get 12 V to the injector connector. I’ve checked this on both the new and old valve cover gasket. The voltage I get on the injector connector is 0.26. Is this my problem or is there something else?
Old Mar 25, 2026 | 09:30 AM
knottyrope's Avatar
knottyrope
You have several things goin on
Biggest pain is you have air in the HPOP system now. Its going to take a bit to remove with a lot of cranking.
For injectors issue. Ohm out your harness from the 42 pin connector.
https://www.ford-trucks.com/forums/1...load-test.html
Have a Scanner? That is going to save you 1000s in guess work
https://www.ford-trucks.com/forums/1...2-scanner.html
welcome to the club wagon
https://www.ford-trucks.com/forums/1...sel-truck.html
Hector370zT
20
Apr 11, 2022 07:58 PM
westcoastslider
Sep 5, 2020 04:38 PM
JMP E350
44
Sep 21, 2015 09:02 PM
WoodHacker
Sep 15, 2014 10:41 AM
krzyk26
Apr 3, 2005 04:19 PM
