Code C0300 - Where is the Rear Propshaft speed sensor?
Old Mar 23, 2026 | 06:47 PM
greenlight25's Avatar
greenlight25
2nd Gear
I have a 2010 F-150 XLT, only about 110,000 on it. The other day it pretty much broke down, (long story short it had some timing issues but that's not my problem right now) and the main issue was fixed. The mechanic who fixed it cant seem to find the origins of the problem that I keep having which is sometimes, the truck will drop its idle rpms and shudder, once or twice it has even stalled on me. I have an AutomendPro OBD sensor, and it gives the the code C0300, which says rear propshaft speed sensor. The only issue is, I cannot find it. Some forums/videos say it is on the outside of the transmission, others say it is in the lead case of the transmission, I've even seen someone say it is actually on the rear diff.
Is this a sensor I can fix on my own without cracking into the transmission, or should I find someone who can do it proper. I also have a 6R80 6-speed auto transmission.
Or, do you think this sensor isn't even the problem, and I should look elsewhere?
Old Mar 24, 2026 | 03:03 PM
projectSHO89's Avatar
projectSHO89
I have an AutomendPro OBD sensor....
Get and use a different scan tool. Neither DTC (C0300 and C0700) exists in the factory service manual for your truck.
Old Mar 24, 2026 | 03:05 PM
greenlight25
2nd Gear
do you have a recommendation for a scanner?
Old Mar 24, 2026 | 06:32 PM
projectSHO89
My preference is to use Forscan on a Windows laptop using either an OBDLink MX+ (Bluetooth) or a Forscan-recommended USB-connected OBDII adapter.
There are plenty of other options out there.
austin78
Sep 21, 2024 11:42 PM
homertwo
Nov 7, 2023 02:31 PM
GhostComanche
Feb 25, 2021 12:01 PM
chris1996
Oct 10, 2016 09:28 PM
skyfox10
Modular V10 (6.8l)
Apr 14, 2014 08:06 PM
