MAP Sensor
Old Feb 11, 2021 | 09:48 AM
GhostComanche's Avatar
GhostComanche
MAP Sensor
Do you think this sensor needed cleaning? 30K and it was totally clogged. 2019 250 Powerstroke.................RR
Old Feb 11, 2021 | 12:25 PM
Kellem's Avatar
Kellem
It had to have thrown a code, that's filthy.
Old Feb 11, 2021 | 12:49 PM
GhostComanche
Surprisingly it did not...............RR
Old Feb 11, 2021 | 01:02 PM
senix's Avatar
senix
Do you do a lot of idling or low speed stop and go?
Old Feb 11, 2021 | 01:30 PM
GhostComanche
I got the truck with 24K on it, and not really many idle hours. Drive mainly back and forth to work 15 minutes each way, except for hunting season when it gets used hauling Camper and side by side. I will start checking the sensor at every oil change from now on. Thanks much for this forum and all of the valuable content in here.
Old Feb 11, 2021 | 01:51 PM
frambach's Avatar
frambach
Yeah, I'm a bit curious as the the operating condition for this truck as well.
I'm not indicating it's bad or anything has been done incorrectly. Genuinely curious.
Old Feb 11, 2021 | 02:42 PM
GhostComanche
I do not know about before I purchased the truck, but was clean as a pen on inside and out. Local one owner that was very well maintained. I am OCD on service and cleanliness of the vehicle. Since purchase, I have converted into a poor mans Tremor minus the 10 speed (LOL). Bilstein shocks, Bilstien dual steering stabilizer,skid plates, programmer, 35x12.50 AT2 Extremes,and many other goodies. Don’t beat up on me too hard guys; really like this ride....................RR
Old Feb 11, 2021 | 07:28 PM
Motown Fire's Avatar
Motown Fire
Good looking truck. Thanks for the heads up on the map sensor. Time to pull mine & take a look at it.
Old Feb 12, 2021 | 04:22 PM
Keith Griffin's Avatar
Keith Griffin
I pulled mine on my '17 with almost 65k miles on it and it wasn't quite that bad. I pulled it cause I was getting a code, cleaned it up and thought that might help clear it. Turns out the MAF sensor was bad. Replaced under warranty and the truck has been fine since then. I probably won't check it again for 25,000 miles or so.
Old Feb 24, 2021 | 11:33 AM
SUPERTRUCKERS's Avatar
SUPERTRUCKERS
Was curious after seeing this...pulled mine and cleaned it up. 40K miles. ~ 18% of engine hours is from idling. Have others pulled and inspected? Here are the before and after pics.
Old Feb 24, 2021 | 11:17 PM
brandontolentino's Avatar
brandontolentino
Any noticeable difference after cleaning? S&B just started selling a spacer that is supposed to eliminate the problem....
Old Feb 25, 2021 | 08:40 AM
deveroutdoors's Avatar
deveroutdoors
What did you clean with? Scrape out (gently) residue and hit it with brake cleaner?
Old Feb 25, 2021 | 09:14 AM
SUPERTRUCKERS
I went the microfiber cloth, scrape out gently method...no chemical cleaners.
Old Feb 25, 2021 | 10:38 AM
4wd6.7L's Avatar
4wd6.7L
After finding this thread I google searched the subject and found what appeared to be a forum with techs discussing it. One said that if anything(cleaner?) gets to the electronics inside the MAP it's toast. I was a little surprised as I've used electronics parts cleaner liberally on Toyota MAF sensors without any issue.The MAP sensor must be a different animal.
So you just try to gently knock off the build up, does it build up in the hole much?
Old Feb 25, 2021 | 11:05 AM
Martin6's Avatar
Martin6
Looks like S&B is still waiting for an EO Number from CARB before selling to California. The spacer does look promising though.
