Tire question
Old Mar 23, 2026 | 01:42 PM
Doc Nash's Avatar
Doc Nash
Tire question
Looking to possibly run these classic bias ply tires on my F1004x4. Not sure how wide of a rim
i need tho. Anyone run these Gateway/Maxxis Buckshot Mudders?
https://ntwonline.com/n78x15c-30x8-50x15-buckshot-mudder-bias-ply-bsw-gateway-tire/#tab-description
Old Mar 24, 2026 | 12:38 PM
fe390pc's Avatar
fe390pc
I am fairly certain you can run those on standard wheels.
Old Mar 24, 2026 | 12:55 PM
Doc Nash's Avatar
Doc Nash
As in the stock 1969 15x6 Ford rims?
Old Mar 24, 2026 | 03:40 PM
WDXPW's Avatar
WDXPW
Its going to be very loud.
Old Mar 24, 2026 | 04:30 PM
Doc Nash's Avatar
Doc Nash
yeah, I was thinking the same
thing, but not planning on it being a daily. Any idea what size I can run? Truck has no lift, just stock 4x4. I was thinking 33’s should be good?
Old Mar 25, 2026 | 11:06 AM
fe390pc's Avatar
fe390pc
For the tire size it depends.
1) What is your plan for the truck? (Off roading, cruising, just some yard work)
2) What engine & trans do you have, if its a 6cly with 3 speed stay with that tire size.
Old Mar 27, 2026 | 12:38 AM
Doc Nash's Avatar
Doc Nash
1) cruising, some off-road, nothing super serious.
2) came with a 360, it MIGHT have a 428 (see previous posts) and factory 4spd manual.
From some Facebook feedback, I’m steering away from this tire and considering some others.
All options are 33x10.5x15, with Wheel Vintiques 15x8 steel wheels.
Old Apr 1, 2026 | 04:30 PM
fe390pc's Avatar
fe390pc
The Geolandar or the Grabber are good economical options in my opinion.
Old Apr 2, 2026 | 06:54 AM
Diveboss's Avatar
Diveboss
I'm running BF Goodrich Mud Terrain 31 x 10.5 x 15 on stock rims 15 x 6". I have factory new rear springs at stock height and 1.5" lift leveling kit in front.
I can tell you with fair certainty that with stock height, you will rub if you go 33 x 12's with factory rims. If you go with aftermarket rims with a fair amount of offset, you may get away with it.
I actually had to use 1/2" wheel spacers with mine as I was getting a little running at full turn, but the spacers did the trick.
Truck is 67 F100 SB
Old May 12, 2026 | 05:05 PM
Doc Nash's Avatar
Doc Nash
Truck is 67 F100 SB
Looks good! Is that 2wd or 4wd? Mine’s 4wd so I’m thinking it should have more height/clearance than a 2wd.
fiveton
Mar 31, 2025 07:45 PM
FOURBYBUD
Jun 22, 2021 07:15 AM
mslopnick
Apr 9, 2016 05:43 PM
JoeyGowdy
Oct 6, 2009 08:17 PM
scottddove
General Automotive Discussion
Feb 24, 2009 05:43 AM
