Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
ultimate gremlin
Old Mar 21, 2026 | 11:49 AM
BMWSID's Avatar
BMWSID
3rd Gear
ultimate gremlin
1992 E350 with 351 W engine. All at once, on a trip, it started running bad. Was fine up to then. (only has 44K miles on it) No power., got us home, barely. Did all kinds of diagnostics on it, tried 3 other computers, all new ignition components, new cat. converter, Had it to 2 different shops, they cannot find the problem. I was told the compression tests fine. The second shop said on a leak-down test, cylinder 4 has a leaking intake valve, and cyl. 8 has a leaking exhaust valve, (or vice versa) How was the compression tested OK then? The second shop had it for months! (irrelevant) I had to pay those shops enough to buy a replacement engine by now, but it looks like a very tough job to R&R it! I am near the Charlotte Motor Speedway, I would think there would be a good Ford mechanic around here, but they don't want to work on anything this old! They want huge money to switch it out for me!
Last edited by BMWSID; Mar 21, 2026 at 07:49 PM. Reason: Can't read the difference in 8 or9!!, cant spell, either!
Old Mar 22, 2026 | 10:47 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Two things to try the easiest is replace the MAF sensor and the second is to remove the valve covers and look for a bad valve spring. A bad valve as spring will cause all sorts of miss fires on port fuel injection motors.
Denny
Old Mar 23, 2026 | 01:04 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
A slightly leaky valve or two with good compression won't cause "All at once, on a trip, it started running bad" and "No power., got us home, barely".
Also, a leak-down is over time, while compression is in the moment while cranking the engine. You can have good compression while having slightly-leaky valves.
You're going to have to go into more detail here:
- Specifically what new ignition components?
- Why was the cat replaced? Was it diagnosed as plugged?
- What were the compression numbers?
- What does "running bad" mean? Misfiring? Shaking? Knocking? Noises? Etc.
Old Mar 26, 2026 | 06:33 AM
B-ManFX4's Avatar
B-ManFX4
It takes three things for ICE - compression, fuel and spark. If it has those three things, it is likely an ignition / electronic control part that crapped out, especially with sudden onset of running but no power.
Here's a troubleshooting list, courtesy of ChatGPT, when I asked this question: 1992 Ford 351-W V-8 suddenly loses power under load. What is wrong?
ChatGPT Answer:
Possible causes (prioritized by likelihood and ease to check):
1. Fuel delivery
- Clogged fuel filter or weak fuel pump → low pressure under load. Check fuel pressure at rail (spec ~4–6 psi for EFI of that era; carb models: ensure bowl fills).
- Carburetor issues (if carbureted): clogged jets, stuck accelerator pump, or collapsed float needle → lean under load.
2. Ignition
- Weak spark under load: worn points/condensor (if distributor points), bad coil, cracked plug wires, fouled or worn spark plugs, or a failing ignition module. Inspect plugs and wires; check coil primary/secondary and dwell (points) or module operation.
- Distributor advance stuck (mechanical or vacuum advance) → wrong timing under load.
3. Sensor/fuel metering (if EFI)
- Bad MAP/MAF (if equipped), TPS, or fuel pressure regulator causing lean mixture under load.
4. Air intake / vacuum leaks
- Large vacuum leak can cause lean condition under load. Inspect hoses and carb / EFI gasket.
- Restricted air filter or intake obstruction is less common but possible.
5. Timing
- Timing jumped (loose timing chain or slipped gear) → loss of power, especially under load. Check timing marks; excessive chain slack or worn sprockets.
6. Exhaust restriction
- Partially clogged exhaust or collapsed catalytic converter (older pre-cat trucks may have muffler/exhaust blockage) → power loss under load and increased backpressure.
7. Mechanical issues
- Low compression (worn rings, burned valves) — does problem occur at all RPMs? Perform a compression or leak-down test.
- Valve train problems (broken spring, valve not seating) causing sudden loss under load.
Quick checks to narrow it down (do in this order)
1. Listen for misfires; inspect spark plugs for color/wear.
2. Check ignition coil, wires, and distributor cap/rotor.
3. Check for vacuum leaks and condition of vacuum advance.
4. Check fuel pressure.
5. Verify timing at idle and with slight revs; watch for jump/misalignment.
6. Scan for any codes if EFI or electronic ignition present.
Old Mar 26, 2026 | 11:27 AM
B-ManFX4's Avatar
B-ManFX4
https://www.ford-trucks.com/forums/1...l#post20615603
Old Apr 1, 2026 | 08:59 PM
BMWSID's Avatar
BMWSID
3rd Gear
I checked compression on #4, it was 70PSI, and the plug was wet with gas and oil. Comp. on #3 was well over 100, I didn't write it down.
The cat was replaced because the metal tube feeding the EGR valve had rotted off, and we had an EGR valve fault. I am not sure if the old cat was plugged, I doubt it, because nothing got better. Replaced that EGR valve, too
All plugs, wires, cap, rotor were replaced, nothing got better.
'running bad,: missing, shaking (Rough idle) just no power. Can not move off pavement without taking it up to about 2K and yanking it into gear and flooring it.
The last mechanic that had it let it idle for hours on end, said he had to put gas in it twice),,,,I suspect the #4 cylinder is washed out, I might either need another gnhine, or find a dealer taking in trades, one of those deals where if you can drive it into the dealer, we guarantee whatever they are offering. All 6 new tires, brakes, worked on the interior for a year with my wife who got to go in it once before she passed away. I am already way underwater on it! It is an aluminum frame one, so it has that going for it...
Mustangking1
Oklahoma Chapter
Apr 13, 2016 11:40 AM
herthcd
May 18, 2010 06:53 AM
dzdiggin'dude
Modular V10 (6.8l)
Mar 10, 2009 02:17 PM
packlet
19
Dec 9, 2006 06:25 PM
pixelmation
1978 - 1996 Big Bronco
Nov 4, 2006 11:55 AM
