E4OD Overheating?
Old Mar 18, 2026 | 03:57 PM
Aedhasdad's Avatar
Aedhasdad
E4OD Overheating?
So went to run errands today, about 4 miles in, stopped at an all way stop, my turn - went then lost all drive - engine spinning, in D - no motion.
Pulled over > P > D - worked again.
Went to Orielys to dump old oil, got back in the truck, intersection with lights, my turn - had to give it plenty of gas then it surged into motion, then 400 yards and i have no drive again, coast into a Fry's Parking lot, push the last 100 yards out of a fire lane.
Check ATF Levels = off the dipstick, no drips under, no leaks visible.
Walk to auto zone and buy a gallon on AFT, dump half in - still nothing. dump another ¼ in, work the gears, give it some revs then something... check the level again - off the dipstick, add the rest of the ATF, drive home.
4 miles to home, few all way stops, and some road works, delay between foot on the gas and motion getting worse and worse - made it home by the skin of my teeth, check the level - off the dipstick. pour in more ATF - thick smoke from the filler tube...
Add abother half gallon then limp the truck into my driveway, slipping gears, no OD, delayed shifting and on the last mile or 2 - no 3rd or 4th gear.
Thoughts?
Overheating? am stumped.
Many thanks in advance.
Old Mar 18, 2026 | 04:35 PM
90project5.0's Avatar
90project5.0
Check the radiator!
Old Mar 18, 2026 | 04:52 PM
Aedhasdad's Avatar
Aedhasdad
Originally Posted by 90project5.0
Check the radiator!
Will do - what am i looking for? you think theres a blockage or something?
Old Mar 18, 2026 | 04:55 PM
90project5.0
You're looking for your radiator broken between the two coolers. Basically your coolant when you remove the cap might just be real nice and pink and frothy. Also, climb under looking to see if your undercarriage is covered like a seal blew out.
If your radiator is clean, then take another vehicle to get more atf. Put the atf in with the truck in neutral and e brake applied. Let it sit in the same spot and run until you find the puddle.
Old Mar 18, 2026 | 05:01 PM
Aedhasdad's Avatar
Aedhasdad
Thank you - will go and inspect when i get a minute.
Old Mar 18, 2026 | 05:03 PM
90project5.0
No problem, report back with findings!
Old Mar 18, 2026 | 06:54 PM
AuroraGirl's Avatar
AuroraGirl
blocked and restricted cooler circuit, my truck had no aux cooler but the radiator had the line to it with a kink. It also puked its fluid multiple times. I had the wrong atf and overheated more than once. Definitely check the cooler flow. Can you give more info about your truck
Old Mar 18, 2026 | 09:20 PM
wwhite's Avatar
wwhite
What about manual 1st and manual 2nd?
how about reverse?
Old Mar 23, 2026 | 10:18 AM
Aedhasdad's Avatar
Aedhasdad
how about reverse?
whilst i was experiencing the slippage - no gears worked.
once it cooled down and i added fresh atf - i had traction again, got worse and worse the closer to home i got.
Ill try to inspect the radiator today - been so busy (we became citizens on friday).
Old Mar 23, 2026 | 11:19 AM
90project5.0
Congrats! I’m sure you’re glad to have that done!
Old Mar 24, 2026 | 09:21 AM
1Butcher's Avatar
1Butcher
Welcome! I bet that was a very long/expensive ordeal. Where did you originally come from?
Many of my clients are emigrants and those people seem to be the proudest Americans I know. The most bitter seem to be the ones that have not experienced how well we have it.
Old Mar 24, 2026 | 10:03 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Some of us have had the foreign European citizenship imposed upon us. We don't all share the same perspective and life experiences within US settler colonialism.
Old Mar 24, 2026 | 10:12 AM
AuroraGirl's Avatar
AuroraGirl
can you clarify what this means for you
Old Mar 24, 2026 | 02:36 PM
FORDF250HDXLT
Not here, I can't.
Old Mar 24, 2026 | 03:34 PM
90project5.0
I agree with that 99%! I’ve been to quite a few not so pleasant countries Only to come home and see the lack of appreciation for what people have. The ones that put in the hard work to achieve their goals and succeed have always been some of the best people to deal with. Like everything else, bad apples exist.
Again, congrats on being forced to pay taxes! Haha
rssllshelly
Jan 24, 2024 08:03 PM
icrman
Jun 29, 2022 08:03 PM
NotSoSporty98
Aug 28, 2016 03:06 AM
Brant Bowrifle
Jun 18, 2011 12:46 PM
doc_nomad
Sep 12, 2004 09:04 PM
