I wonder if you might have some injector orings that are aging. Warm them up and add some oil and they seal up better. If you don’t know their age, then they are suspect. It could also contribute to your code on long pulls.
Thick black smoke is fuel being wasted and not normal.
This can be from boost leaks , worn or wrong turbo, an injector failing open, low compression or bad tuning,
just for diagnostics and troubleshooting purposes, the black smoke clears out once I've got on it pretty good like going up and up ramp to an expressway. Or if I'm pulling heavy equipment, it doesn't really do it much then
Oddly enough, when I went out to start the truck today using my usual 60 seconds of glow plug It started up and did not stumble..
Also apologies that I seem to have two issues in the same thread. The bigger issue is the stumbling, but I cannot edit the title. Perhaps the two are related, but bear with me as I continue to work through troubleshooting!
Anyone have the part numbers for connecting a fuel pressure guague to the fuel bowl? Would like to have the correct size and pitch threads and fittings on hand since this is my only vehicle atm.
The LPOP seals were replaced about 1000 miles ago with genuine Motorcraft parts from Riffraff. The ICP sensor and ICP pigtail were replaced at the same time, also with genuine Motorcraft parts from RiffRaff.
The cold-start stumble was happening before that work and is still happening afterward, so I do not think the LPOP reseal, ICP sensor, or ICP pigtail caused it.
It smacks of IPR valve hanging. You can remove it, disassemble and clean it and reinstall it. If it resolves the issue, well, then there you have it. There are instructions and links to videos here and all over the web.
