Grinding noise when driving
Old Mar 18, 2026 | 07:36 AM
Johnchaz's Avatar
Johnchaz
Trailering
I have a 89 f-250 with the 7.3 idi and a zf5 trans. When I am cruising at 45mph there’s a loud grinding noise and it goes away after about 55 mph. It also goes away if I press the clutch in. It almost sounds like a bad belt squeal. Not sure where to look, im assuming I’m going to have to pull the trans figured I’d see if anyone dealt with the same issue before I start tearing into it.
Old Mar 18, 2026 | 07:54 AM
Olds64's Avatar
Olds64
You can start by checking the fluid in your ZF5. Here's a video I found with a quick search.
Source: YouTube https://share.google/3zJLvLe10qeJDX1eP
Old Mar 18, 2026 | 08:13 AM
Johnchaz's Avatar
Johnchaz
Trailering
Will do thanks
Old Mar 18, 2026 | 11:38 AM
Johnchaz's Avatar
Johnchaz
Trailering
I changed the fluid, it definitely needed to be changed it was brown and smelled like celery lol.
rowdy89
Jul 6, 2024 06:07 AM
dnachel
Jul 17, 2023 12:29 PM
Copeland93
Feb 14, 2023 10:05 AM
arkredneck
28
Jun 11, 2011 09:27 PM
hernando
1983 - 2012 Ranger & B-Series
Feb 28, 2004 05:48 PM
