Sponsored by: Auxito
maf readings
Old Mar 17, 2026 | 01:23 PM
Michael Lizotte's Avatar
Michael Lizotte
maf readings
Shop said " MAF sensor is reading to high, truck also idles to high at times." Do you guys agree? What I found online was normal should be at 4.5 to 6 grams per sec at idle, and 11.5 to 17 grams per sec. at 2500 rpm.Can you circle what is bad, so i have something to give to my shop? See attachment...
File Type: pdf
Old Mar 17, 2026 | 04:09 PM
BareBonesXL's Avatar
BareBonesXL
You should ask your shop to show you or tell you what they are seeing. "Too high" doesn't tell you much. If they've already decided to sell you a MAF sensor showing them a Chat GPT thing probably won't help.
And, why is it in the shop? Is there a code? Are you still working on the P0174 code? MAF sensor is often suggested as a cause for that. But on the 4.2 it's usually the intake manifold gasket leaking because of bad isolator bolt bushings or the IMRC bushings.
Old Mar 17, 2026 | 04:48 PM
Michael Lizotte
No more lean codes after auto shop replaced my MAF, it seems to run well. I went back to my transmission shop for trans. warranty work, a little bit of a noise downshifting from 2nt to 1st. Trans. shop said to get the MAF repaired first, this can cause some minor shifting problems.They gave me the MAF print out to show the shop that just replaced the MAF. He said "the print out can easily be read, it shows the MAF is running to high" Does the sensor test result show that?
Old Mar 17, 2026 | 05:35 PM
BareBonesXL
I see. I spent some time figuring out the graphs. It looks like you had a MAF sensor reading of 6.6 at 894 RPM at one point, assuming the end of the time plot. That is high. Not sure it would cause a transmission problem but probably worth showing to the shop that did the MAF sensor work.
But, and I'm not sure why, I looked at some of my old scans of my engine and find that a few RPM can make a big difference at idle. At 820 RPM I had 4.4 g/s, at 836 I had a 5.4 and 6.2. I also had a more recent reading of 4.4 at 818 RPM.
There's no engine temperature on the graphs. Can't tell if your engine is fully warmed up. A cold engine will idle higher and have a higher MAF sensor reading.
In short, it doesn't like you have a significant MAF sensor problem. And it's not clear why you have a high idle RPM. The idle RPM might be the real problem.
Old Mar 18, 2026 | 05:19 AM
manicmechanic007's Avatar
manicmechanic007
You can get a reference table of pids from AllData for your 4.2
That way you can compare all the pids with the reference table
Some MAF tables are in pounds per hour, so you have some math to do sometimes
Old Mar 18, 2026 | 08:29 AM
Michael Lizotte
Thanks for taking the time to help. All I have is a basic scan tool. I was hoping with the graft it would be something that was easy to see. Anything past my Haynes manuals I'm lost, trying to learn more . If it helps my temp was at 190 and he ( trans shop) sat in the truck and read the codes. I never seen it "some times idles high" seems to idle fine at about 900. My impression at the trans. shop was they didn't really want to repair the trans under warranty, they said it can shift a little hard because of the new shift kit.
Old Mar 18, 2026 | 08:31 AM
Michael Lizotte
You can get a reference table of pids from All Data for your 4.2
Thanks I'll ask about that at the shop. This part of repairs is way over my head.
Old Mar 18, 2026 | 10:10 AM
BareBonesXL
Is it shifting hard from Park to Drive or is it shifting hard between gears while rolling? One might be a high idle problem, the other something else. I don't think a high MAF sensor reading is going to affect shifting behavior.
Just curious, but did you have the transmission rebuilt or did you have a special shift kit installed? Usually "shift kit" means a change in shifting behavior. Snappier, harder. A "rebuild kit" would restore factory performance.
Whatever it is, good luck with it.
Old Mar 18, 2026 | 12:32 PM
Michael Lizotte
shifting issue
I had it rebuild because it would not shift into reverse and there was a little shutter in all gears. The only issue after rebuilt is I have a small noise going from 2nt to 1st, I was told noise should go away in time. I told them the noise didn't go away with time.They said they added a shift kit can't remember the brand.
Sandia_park
Aug 12, 2025 12:34 PM
jrlowscot
Feb 24, 2024 05:23 AM
Pocketlint
Jul 9, 2017 06:36 AM
skibender
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 24, 2003 10:53 AM
