Sponsored by: Real Truck
throttle pedal issues
Old Mar 12, 2026 | 11:13 AM
Cajun Kirk's Avatar
Cajun Kirk
7th Gear
Gentelmen:
New to this site and looking for help into solving a throttle pedal problem.
Lost action about a year ago. Changed pedal then ECM. A few weeks ago, lost pedal action. Replaced new pedal, disconnected OD wires (as instructed by Ford dealer Mech) dead pedal. On 4th pedal now,
I have all dash working, fuse #45 not blowing, change connector plug at pedal, checked wiring from ECM to fuse box , pedal connector and beyond.
What voltage should be at pin 1 on a fixed pedal. Doorman #669-203. I have 12 v with ign. on. 5 v on pin 5.
Pin 2 receiving slightly ground to chassis.
Ohm pin 3 to 4 I get 1093 idle to 2570 WOT. pin 3 to 5 is 2712 idle to 1280 WOT.
I have checked & rechecked every plugin from rear to front.
What could be causing the pedal malfunction.
Old Mar 12, 2026 | 01:28 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
17 years of several models each year..... many configurations for each.
Think about that.
Old Mar 13, 2026 | 06:54 AM
Cajun Kirk's Avatar
Cajun Kirk
7th Gear
throttle pedal issuses
Sir:
Pushing 550,000 miles. Love this truck. I have changed 4 pedals now, ECM a year ago, searched every possible wiring problem from rear end speed sensors to trans shiftier. Checked all components in engine bay. I have ran ohm test from pedal to fuse box, ECM, I have mechanical skills and now searching for any leads of direction.
Old Mar 13, 2026 | 12:41 PM
Pikachu's Avatar
Pikachu
To put it a bit less passive aggressively, what is the year/model/engine.
Old Mar 13, 2026 | 01:44 PM
Cajun Kirk's Avatar
Cajun Kirk
7th Gear
2002 F250 7.3 diesel lariat 4 door. I pulled dash out today looking for any type wiring scraps or breaks. Non. run ohm test from pedal connection to ECM board, nothing shorts out. Ran test from fuse #45 to board, no shorts.
Could it be possible anything on trans or deferential? My next test will be trailer connection wiring.
Old Mar 14, 2026 | 07:27 AM
Cajun Kirk's Avatar
Cajun Kirk
7th Gear
Gentlemen:
After reviewing many sites, I have a 9 pin connector for a dorman 699-203 pedal for 2002 f250 7.3 diesel.
Pin #6 shows hot from ign, red/yel wire. I am getting 12 volt at pin #6. Is that correct voltage or should be 5 volts?
I have traced all wiring to ECM and fine no shorting using ohm testing.
Put new accelerator pedal in, starts, have pedal response, test drive, after 100 feet, fuse #45 blows.
Now fuse does not blow.
Brown/wht wire has 5 volt. Yellow/wht wire shows ground to body.
Is there a voltage resistor somewhere in the system I am not finding for pin #6?
Old Mar 14, 2026 | 01:03 PM
Pikachu's Avatar
Pikachu
Pin 6 should be +12v on a red wire with yellow tracer. It comes from fuse 45 and is powered in start and run. Pin 10, brown with white tracer is +5v VREF. Was fuse 45 blowing with the APP sensor disconnected or only when it was connected?
Old Mar 14, 2026 | 08:44 PM
Cajun Kirk's Avatar
Cajun Kirk
7th Gear
Sir:
Pedal was connected. Starts, runs fine until I drive about 200 ft, blows fuse #45 sometimes. No pedal response after that. replace pedal to try another.
I have spent all day unwrapping harness from rear end to trans. checking each plugin at sensors. No breaks in wiring. Started in engine bay found maybe a brown wire at connector going to engine sensors going to fuel delivery. Will try deeper with ohm testing each wire from ECM plug to each sensor.
Using Dorman 669-203 pedals, only one I could find locally. I changed pedal connector, matched wires perfectly.
Thank You for responding.
Old Mar 14, 2026 | 09:22 PM
ifrythings's Avatar
ifrythings
Fuse 45 feeds the overdrive switch which is extremely common for breaking the wires at the bottom of the shifter and shorting out, I would start there.
Old Mar 16, 2026 | 09:25 AM
Cajun Kirk's Avatar
Cajun Kirk
7th Gear
I ohm the wiring from the 3 pins to button, no shorts. checked OD button, working properly. diode is directional it"s working.
Should I reconnect the OD wiring or leave off? Mach. at Ford dealership told me to leave off. Don't really need to reconnect.
Ohm out the following wiring and found that : Pin #6 - red /yellow = 12 volt in ign. on
Pin# 7 - red / Lt green = IVS going to ECM plug #10
Pin # 8 - Gray / wht = AP/ITC signal going to ECM #89
Pin # 9 - Yellow /wht = Ground going to ECM # 24
Pin #10 - Brown / wht = VREF going to ECM # 90
A friend has a better scanner I will put on to try to locate more info from ECM.
Old Mar 20, 2026 | 10:06 AM
Cajun Kirk's Avatar
Cajun Kirk
7th Gear
Gentlemen:
An update on my problem with the accelerator pedal not working after replacing 5 times.
I pulled front driver tire & fender well to get assess to IDM, After checking each wire carefully, I found a green/ red ( ground wire) had chafed not making complete contact. The ohms read correct but could not handle the load needed. I traced it back to the pedal and ECM to make sure where it went, After weeks of tracing wires, I hope any information I have listed will help others on their problems. Truck starts, runs fine and have no other issues.
Cajun Kirk
jtradford
Dec 30, 2020 08:22 AM
hello113
May 18, 2019 12:08 AM
Corey Boucher
Dec 21, 2018 07:41 AM
Iasphynx
Feb 28, 2013 08:08 PM
Bertelrud
Jun 7, 2009 02:25 PM
