2025 F250 7.3 - A/C Delay
Old Mar 11, 2026 | 06:14 AM
B52's Avatar
B52
I've been noticing recently that my a/c compressor doesn't seem to engage until 30 seconds or a minute after turning the a/c on. Ambient air temps in the low 80s. I get in the truck, start engine, roll down windows, wait about 30 seconds, begin driving, roll up windows after a minute, then start a/c. Once the a/c does decide to work, it's ice cold within a couple seconds. I've not verified if the compressor is actually engaging, yet. I've also not ruled out a blend air door issue. Is this normal operation?
Old Mar 11, 2026 | 03:57 PM
kbass24emtp's Avatar
kbass24emtp
There is a TSB on the compressors for that year. It should of been done prior to you purchasing it from the dealer, but I would call and check.
Old Mar 11, 2026 | 08:44 PM
the1adman's Avatar
the1adman
This is exactly how my 2024 works. Not sure if its normal but its annoying.
Old Mar 12, 2026 | 06:32 AM
B52's Avatar
B52
I remember reading about this a while back. Is this the TSB you're referring to --> https://static.nhtsa.gov/odi/tsbs/20...16357-0001.pdf
Old Mar 12, 2026 | 06:42 AM
B52's Avatar
B52
Agree, it is annoying. Even the HVAC cabin air fan on this truck has a delay. There's like a 5 to 10 second delay between turning the fan **** on and the fan actually turning on.
Old Mar 12, 2026 | 10:05 AM
6.2caribou's Avatar
6.2caribou
My '25 F250, with a May '25 build date, has these same delays. It's been checked by the dealership and passed whatever the TSB's requirements are.
Old Mar 14, 2026 | 08:58 AM
kry226's Avatar
kry226
I also get it on my 23 from time to time as well.
Old Mar 14, 2026 | 09:47 AM
Vet14tango10's Avatar
Vet14tango10
Same for my 25 250 may build.
Old Mar 14, 2026 | 11:08 AM
bpounds's Avatar
bpounds
My '24 has climate control. It does the same thing. I actually think it is a design feature, to let the engine stabilize RPM before adding the load of the A/C compressor. It seems to correlate with the RPM dropping from around 1200 at startup down to around 900. I always wait for that RPM drop before engaging the transmission. Less lunge when it drops into gear.
Come on now, you really can't wait 30 seconds for A/C? Just leave your door open for half a minute.
OBS460
7.3L / 6.8L V8 Gasoline Engines
Sep 20, 2022 03:26 PM
Jlwhitt77
18
Feb 19, 2021 12:25 PM
wreedZ71
2004 - 2008 F150
Jun 2, 2008 07:34 PM
DickyBoy
Sep 9, 2006 05:51 PM
whoop09
1978 - 1996 Big Bronco
May 8, 2004 03:29 PM
