Sponsored by: Real Truck
6.0 advice needed
Old Mar 9, 2026 | 07:56 PM
Danebramage's Avatar
Danebramage
4th Gear
6.0 advice needed
Hola, amigos! Just signed up.
Seeking some advice/insight/etc.on my 6.0 project ('06 F250) Scenario: I noticed no issues but conducted a once-over before heading out of town. Noticed grey sludge in degas...so much for taking the truck! I'm deep into the valley with the cooler removed and new one on way (USA version.....-CA number). Since I'm elbow deep in this, I'm updating where feasible. I removed the radiator to have it hot tanked but since it's OE, that won't work. ~$200 in labor for shop to clean out thoroughly and it has ~225K miles on it, so I'm upgrading to a Mishimoto rad. I'll put on new pipes, hoses, pump, etc. My big issue is the HPOP. I don't think there's an issue. I pulled the IPR and it looks good other than a few small solids. Screen looked good from my perspective. (BTW, who ever installed the IPR wrenched way too tight. Took a pipe wrench, for Pete's sake!) This is a reman longblock truck installed in '14. I looked at the itemized invoice and not seeing a HPOP listed so apparently the old HPOP was transferred. As mentioned, there are ~225K miles on the truck minus the longblock. Bite the bullet for a new HPOP since i'm that deep into it? I'm thinking the River City Thump 1 HPOP if i do. Or, upgrade the STC fitting (assuming it needs it) and the IPR and call it good.
Thank you for you input!
Old Mar 10, 2026 | 07:43 AM
Baylinerchuck's Avatar
Baylinerchuck
Just curious why you feel the need to replace the HPOP? Was it under performing? The ‘05 and up design is pretty solid. Are you sure the sludge is coming from the oil cooler? Did you pressure test it? What were the deltas? Did you pressure test at the degas bottle to ensure the head gaskets are good? EGR cooler? As far as the new oil cooler you bought, it is 99% going to be the Chinesium version. Motorcraft doesn’t have the USA version anymore, they sold all remaining stock of the good ones to BPD and a few other places. They do however still sell the USA gasket kit. You would do well to pitch the Chinesium gaskets that came with the oil cooler and buy a gasket kit from a reputable Ford parts dealer. The oil cooler itself will be ok-ish, but the gaskets that came with it are known to leak. Crappy parts is just another battle we are facing from Ford on these engines.
There’s lots of information on all this and more in the 6.0 section of the forum. You should repost over there and get answers from the most knowledgeable folks who have been there done that.
Old Mar 10, 2026 | 10:34 PM
Danebramage
4th Gear
Thanx for the input. Head gaskets are fine. The new oil cooler is indeed an American version; thus, the......-CA number reference. (BPD purchase).
Old Mar 10, 2026 | 11:51 PM
Baylinerchuck
IMO leave the HPOP, replace the STC fitting if not already done and let her eat.
Old Mar 11, 2026 | 02:43 PM
Danebramage
4th Gear
Yeah, think i'm changing to your way of thinking.
Getch357
16
Aug 11, 2025 09:20 AM
Motohead911
Jul 24, 2024 10:27 AM
kmrod
Oct 6, 2015 07:02 AM
Drake430
May 11, 2014 04:19 PM
merlins'92f250d
Mar 8, 2005 07:01 PM
