Sponsored by: Real Truck
Help Needed With V10 3 valve
Old Mar 6, 2026 | 01:17 PM
fishingbucks's Avatar
fishingbucks
3rd Gear
I recently had my engine rebuilt and it runs great when it’s running. Did have some misfires and stuff at the beginning after rebuild. I think it worked itself out. All new plugs, coil bolts. The coils are still original and worked fine before rebuild. All electrical was sound before pulling motor. It has developed an issue of not starting the next day after leaving the battery hooked up overnight. It cranks fine just wont start. If I reset the computer, it will fire right up. When I first plugged in main harness after rebuild I did accidentally bend some of the pins. I straightened them out and again will crank and run after reset. Any ideas?
Old Mar 6, 2026 | 08:15 PM
ashleyroachclip's Avatar
ashleyroachclip
Check codes before resetting the computer , after you have tried starting the next day .
let us know what you get .
Old Mar 9, 2026 | 08:11 PM
fishingbucks
3rd Gear
It’s the PCM main female connector
So, after more troubleshooting, I have discovered it’s the main (biggest) female connector on the (pcm side). It’s cracked and missing one of the latch anchors and one of the plastic guides in the middle. This explains why I bent pins trying to connect it the first time back after rebuild. The male side will not stay seated in connector. The slightest vibration or move causes a stall, no start, or horrible idle. I figured it out by removing pcm and plugging back up with pcm vertical with stress on connection and wiggling it around.
So, I really need a new connector on the pcm side. I’m betting I’m gonna have to get a different pcm. Then, what about programming? I’d be terrified to ask what it would cost at a dealer.
Old Mar 11, 2026 | 09:57 AM
crashz's Avatar
crashz
Could you get creative with some zip ties to hold the connector in place? Make a choker and use that to squeeze the connector into the pcm socket?
Old Mar 11, 2026 | 11:26 AM
Pikachu's Avatar
Pikachu
The center bolt doesn't keep it seated?
Old Mar 12, 2026 | 04:13 AM
ashleyroachclip
My pcm connector , is heald with a 10mm bolt ,on my 99 ...odd
rock2610d
Modular V10 (6.8l)
Oct 2, 2020 05:05 AM
TXtinct
Jul 23, 2011 05:43 AM
bamaboy473
Modular V10 (6.8l)
Aug 15, 2010 02:55 PM
DaBossF250
Modular V10 (6.8l)
13
Oct 20, 2007 06:54 PM
MrRottnDog
Modular V10 (6.8l)
13
Aug 5, 2003 11:28 AM
