I have a 94 f150 can't figure out hard shift
I have a 94 that was a manual from the factory. The transmission is an automatic. I have replaced the sensor on the rear axle, the computer, the transmission itself, the speedo, the rear brake housing and the bulb, the fluid is great its new too. When I drive I feel a clunk I guess and the vehicle rocks from from front to back. When I put it in drive or any other gear it rocks too. Something just isn't right. Any help appreciated.
When parked into drive, or while driving?
Rocks? please explain.
It sounds like you’re describing a swap or repair involving the Ford E4OD behind a Ford inline-6 (300 I6), and now the truck rocks or jerks when going into Drive/Reverse and during shifts, sometimes with a pop. From what you wrote, a few things stand out.
✅ Things I would check first (in order):
1. Missing or incorrect wiring harness
You mentioned you didn’t get a harness but did install the MLPS (Manual Lever Position Sensor). On an E4OD this matters a lot because the transmission is electronically controlled by the ECM/PCM. If the wiring isn’t correct:- The computer may not know the gear position
- Shift timing and line pressure can be wrong
- It can cause hard engagements or rocking when shifting
2. MLPS alignment
The MLPS must be perfectly aligned in Neutral during installation. If it’s slightly off:- The PCM thinks the truck is in a different gear
- It can cause harsh engagement, popping, or rocking
- The truck may slam into gear
3. Wrong computer (ECM/PCM)
You said the computer guy asked if anything was changed. That’s important because:- E4OD trucks require a PCM programmed for E4OD
- Some 300 I6 trucks originally had the C6 transmission
- If the PCM calibration doesn’t match the transmission, shifts can be wrong.
4. Engine / transmission mounts
The rocking and popping could also be mechanical:- Broken engine mount
- Bad transmission mount
- Loose crossmember
5. Driveline slack
Also check:- U-joints
- Driveshaft play
- Differential backlash
6. Torque converter / line pressure
If the transmission is working but engagement is very hard, it might be:- Line pressure too high
- Wrong EPC control from PCM
- Sticking valve body
- Confirm the PCM/ECM number matches a 300 I6 + E4OD truck
- Verify MLPS alignment in Neutral
- Check engine and transmission mounts
- Inspect driveshaft U-joints
- Confirm the E4OD wiring harness is correct
Do you know if its a MassAir, or Speed Density, truck, do you know how to tell?
If its Speed Density, there's 4-5 ECM's that can work $200-350, range.
I hope you have junkyards near you, you'll need the correct harness(E4OD) for the correct ECM to tell it how to shift.
This is the pin outs E4OD has its own.
Ford Fuel Injection
Ford Fuel Injection
JMF70
May 29, 2024 04:15 PM
rough runner
Sep 29, 2009 09:36 PM
SmittyD
Jan 2, 2004 09:43 PM
