Redhead steering gear experiences?
Old Mar 3, 2026 | 11:34 AM
Screwtinized's Avatar
Screwtinized
50 years of abuse, it’s time to replace the leaking, wandering steering box. I’ve read good and bad about the redhead boxes, but nothing specific to our trucks. I use it for work, and put a lot of miles on it, it’s gotta be tough. 78 scab f250 4x4.
Experiences? Thoughts? Recommendations?
Thanks gents.
Old Mar 3, 2026 | 12:49 PM
tbear853's Avatar
tbear853
Mine has had one, '77 F150 4wd PS, since about 2012 or 2013, no complaints. Bunch better than the OEM one was, but then it was worn too. They are advertised as having bearing in place of just a machined bushing or bored housing at output shaft, and new ***** in machined new races.
Old Mar 3, 2026 | 02:44 PM
motorsickle1130's Avatar
motorsickle1130
I still have one on my to do list; also a 78 scab 4x4, with Dana 60 PS.
The only reason I haven’t yet is it’s so expensive, and mines not terrible yet.
I looked at the Blue Top boxes too, but their additional costs added up fast, and RedHead is just up the road from me.
Old Mar 3, 2026 | 02:54 PM
tbear853's Avatar
tbear853
Originally Posted by motorsickle1130
..... and RedHead is just up the road from me.
I ordered one on a Monday, it was in my driveway Wednesday, Core went back as quick and I soon had my deposit credited back. They is in Seattle, I'm not in Seattle.
Some here should try to put together another "group buy", it sure saved me some "jingle".
Old Mar 3, 2026 | 08:55 PM
crazy96863's Avatar
crazy96863
I retrofitted a late 70’s 1/2 4x4 steering gear into my 75 which originally had manual/power assist. It’s nice being able to turn the wheel while parked engine idling w/ 33” tires with one pinky finger. There was virtually no bleeding required. Yeah lots of credit to Redhead.
I’ve been on this forum for about a decade. Maybe longer. Don’t think I’ve ever heard a complaint about Redhead.
Note: if you’ve got an old steering gear laying around or you find one at pick n pull during a 1/2 off sale, Redhead may give you a healthy store credit for it. Never hurts to ask.
Old Mar 3, 2026 | 10:01 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 Redhead has a great reputation, yes they are fairly expensive and the up front core charge can sting a bit. So when you get the old one off, SEND it back in the same box and get the core charge back. FYI there is a time limit also. Yes Blue Top also has a solid reputation. Both places do upgrade machining to the boxes.
Also a great time to upgrade the bottom of the steering column.
https://drbfab.com/products/all-meta...-76-79-broncos
And since I am making $ spending suggestions, how about a Borgeson steering shaft upgrade. https://www.borgeson.com/70-79-Full-...ord-Truck.html
Old Mar 3, 2026 | 11:34 PM
stpackard's Avatar
stpackard
I did the 78-79 f250/f350 4x4 conversion on the '72 and used the Redhead box. It always works, and still has no slack and good sensitivity. I daily drive mine, have driven it all over, to colorado for trails, etc. and it holds up well. Recommended upgrade, worth the cost to have the upgrade of needle bearings and professionally worked over internals.
Thanks gents.
Old Mar 4, 2026 | 12:19 AM
F-250 restorer's Avatar
F-250 restorer
They are the best. But if you want tight steering, you need tight king pins, steering linkage, tie rods and steering column.
Old Mar 4, 2026 | 09:20 AM
beartracks's Avatar
beartracks
I did Rehead in my 77 1/2, it's great. I did get the quicker steering, in combination with my wide tires and small steering wheel it's a little tight. (also lowered). Not much freeplay in the steering wheel.
Old Mar 4, 2026 | 09:23 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Blue top was good for me in another rig.
Old Mar 4, 2026 | 09:34 AM
440 sixpack's Avatar
440 sixpack
There may be another outfit as good as Redhead, nobody is better. I don't even look anywhere else.
Old Mar 4, 2026 | 09:39 AM
F-250 restorer
I forgot to mention: While the box is out, get a good light and check both sides of your frame where the box bolts in. You may find a crack or two. That is common with these trucks, and you may need a plate welded in place.
thechief66
Oct 14, 2024 10:38 AM
red97stroker
Jul 3, 2023 10:20 AM
RAN84MSU
1997 - 2003 F150
Apr 3, 2007 08:50 AM
