Throttle position sensor
Old Mar 1, 2026 | 08:11 PM
cda97's Avatar
cda97
4th Gear
Are throttle position sensors interchangeable from other Ford vehicles? I would like a Motocraft TPS for my 1987 F150 but I can't seem to source one. Would the one from a Bronco or Mustang work with my throttle body with a 5.0?
Old Mar 1, 2026 | 08:18 PM
90project5.0's Avatar
90project5.0
Bronco would, not sure about mustang
Old Mar 2, 2026 | 08:15 AM
manicmechanic007's Avatar
manicmechanic007
They only made a few different styles
Difference is reverse rotation, and the connector
If it rotates the right direction and the plug plugs in, you're good to go
I still have several in my toolbox for testing
Old Mar 2, 2026 | 03:29 PM
fixitagaintony's Avatar
fixitagaintony
7th Gear
A TPS from any Ford truck chassis (Van, F series, Bronco) will work. The 5.0 and 5.8 are the same ones, not sure about any other engine. If you cant find a motocraft, standard motor products makes decent quality, still working for 2 years on mine at least.
Old Mar 3, 2026 | 01:04 AM
AuroraGirl's Avatar
AuroraGirl
the 4.9 has a different connector (same as the other engines post 96) for the 95 older, and its reverse rotation i think. The 7.5 i think follows the 4.9 design
BigBlue92
Mar 7, 2025 08:39 AM
Mountain_anderson
32
Sep 8, 2024 01:46 PM
Susyqt45
Apr 6, 2023 05:56 PM
frankyford
Nov 23, 2007 10:58 PM
djshel
1983 - 2012 Ranger & B-Series
Dec 10, 2006 02:54 PM
